How to: Tell what head an M20 has, the 2 second way.
  • TurboJake
    • 3780
    If you're like me. You part cars.
    But, if I had a pick-n-pull around me, You bet I'd be there a good amount of the time.
    I've heard stories of people buying engines, and having 200 heads on 2.5 blocks, 885 heads on 2.7 blocks, people selling 200 heads as 885 heads, etc.
    But this is the easy way to tell exactly what head your getting, without looking under the intake manifold.
    The 200 head. Came on the 2.7 ETA. Crappy head. Undesireable unless intent on staying stock. From the exhaust side, look between cylinders 4 and 5. You will see a little casting mark there. It will say 2/7 ETA.
    The 885 Head. Came on the SETA, and the M20B25. Desireable head. The "good" head. Flows much better than the 200. Again, from the exhaust side. Look down at the head above cylinder 2. You will see a little circle there. And on it you will see 2.5 over 2.7. Whether or not you have the extremely uncommon 7 bearing 885 will require you to pull the valve cover. But this gives you a quick idea of what they have.
    Please forgive my leaky valve cover gasket. I'll get on it once it's warm.
    The AMC Head. If you look on the exhaust side, you will not see the 2.7 ETA, or the 2.5/2.7 casting, instead you will see a casted circle with an indentation, much like the blocks core/freeze plugs. You can see that indentation above cylinder number 3 on the exhaust side. That is shown here in the upper left hand corner of the picture. Thanks goes out to users Fporro from here and Sunny Bimmerforums for this picture.
    The 731 head. Came on the 323i from euroland and Australialand. Decent head that can be ported out to the 885 sizes. The picture below shows that you have no casting circles, or the 2.7 ETA head, rather in the center of it between the cylinder numbers 3 and 4 exhaust ports, that there is a small casted port there, which something bolts to. Thanks goes out to user RanierHooker from E30tech for this picture.
    IF you find a discrepancy between your head and this information, PLEASE post it in here or PM me so I can amend it. I still would like some similar shots of the AMC and the 731 one that are similar to the pictures I took of the Eta and 885 head. One broad, and one closeup of casting marks that identify it.
    Leave Me Transaction Feedback
  • TheTacoMan
    • Nov 2011
    • 2308
    Just checked my super etas head, it just says 2.5, rather than 2.5/2.7. Would you happen to know what this means?
    • Boise
      • 212
      Originally posted by TurboJake
      Or, if it does not say anything where you have "2.5/2.7", like mine, then it is the dreaded AMC head. Noooooo....
      Good post, this would have saved me a lot of searching a while back. Keep up the good work!
      • reelizmpro
        • 9536
        87-88 cars came from the factory with 885 heads embossed with "2.5" only and hex headbolts. Even if your car was a super ETA 2.7 liter. 89-on heads had "2.5/2.7". These are the original specs, so if you have an 87 325i with a "2.5/2.7" embossed head and torx headbolts you know they were changed at some point.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Herr Faust Schinken
          • Feb 2012
          • 3580
          I just checked my head I have the little round thing but not the 2.5 /2.7 does this mean I have the cruddy amc head here's a picture
          88 325is Five Speed
          Lachssilber
          • TheTacoMan
            • Nov 2011
            • 2308
            It just says 2.5 there
            Also it does have one spring per valve I checked just in case I had an I head. Also further inspection I found it was an 885.
            • craiggroves91
              • Oct 2009
              • 3024
              I'm not a head expert, but it almost looks like they grinded the badge off
              1989 BMW 325i SOLD
              1998 BMW Estoril Blue e36 M3/4/5 SOLD
              1987 BMW 325 (The Piece) SOLD
              1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
                • Feb 2012
                • 3580
                Thanks looks like I'm gonna haft to pull the manifold off to check
                88 325is Five Speed
                Lachssilber
                • TurboJake
                  • 3780
                  I don't think so, you can now see that I have added the info for an AMC head. You sir have an 885 head with that casting mark just machined or ground off. That casting circle does not exist on the AMC head at all above the #2 cylinder exhaust port.
                    • Feb 2012
                    • 3580
                    Thanks for the info turbojake.
                    88 325is Five Speed
                    Lachssilber
                    • Boise
                      • 212
                      So I always thought my head was the AMC head because it did not say "2.5" on the casted knob above the 2nd cylinder exhaust port. However, I still have the knob (just with no numbers), and I have the circle with the indentation above the 3rd cylinder exhaust port. My head is not original, the PO snapped the timing belt in 2003 and it was replaced with a "remanufactured" head according to the service records. Any thoughts?
                      • jw 325ic
                        • Sep 2006
                        • 1360
                        o/t, you can replace that spark plug wire loom for like $10 from the dealership....
                        • TurboJake
                          • 3780
                          Purely based on the casting surface texture, I'm inclined to say that your head is a BMW head and not an AMC. Every AMC I've seen has a very rough surface, whereas yours is rather smooth and appears to match the valve cover.
                          But if you decide to look and find out what it says behind the intake manifold, let me know. I haven't seen that before.
                          • German Audio Specialties
                            • Feb 2012
                            • 374
                            I have a M20B23 in the shop now, with a known original head. I will snap some pics of it soon
                            August R3VLimited Special: E3012 "V3" box: $225 shipped
                            Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass
                            • Earendil
                              • 1662
                              This is the first time I'm hearing about this AMC head business. I have a "stock" motor in a 325i with no receipt history. Mine looks like yours. I'm wondering where this fits inter the picture? If we figure this out, anyone would be welcome to use my picture as an example.
                              EDIT:
                              I almost forgot. I tore this head down two years ago and took pictures. This is what the backside says. I think it might be. bMW head ;-)
                              1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                              2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                              I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
