DIY Mini Voltage Meter Gauge
  • Atlant
    • Feb 2012
    • 63
    At one point I meant to grab one of georgegraves Volt Meter Gauges but alas he makes them no more so I had to improvise.
    I picked up one of these at Adafruit for $7.95 +SH.
    First thing I did is pop out my stock sound balance switch from behind and start to disablement it (Really simple just pried off the top and bottom off with a flat head.)
    With it all apart the meter almost fit with no modification just had to file down this curve.
    Here is one side done.
    Then I took and rased the raised speaker icons with some sandpaper (obligatory bad pun)
    As an after thought if I had used some higher grit sand paper the finish would have looked a little nicer.
    Then I RTVed the gauge in place with some black silicon rtv. Both top and bottom.
    Put both top and bottom ceramic panels back and and tested it with a 9-Volt.
    Put both clips back in. The ceramic panels fit snug (in the front) but I did not want to permanently attach them in case I want to come back and take it apart so just a piece of electrical tape to hold the panels on.
    To wire it up just connect the red to Acc +12v I used my radios (Purple and white) and the black to ground radios (brown and white I think)
    Finished product.
    Some shots of it in the car. (The gauge was too bright for my shitty camera sorry for the bad pictures)
    There you have it for under 10$ and an easy hour or two you will have a snazzy looking voltage gauge that fits right in the dash and looks stock.
  • JasonC
    Site Manager
    • 14451
    Good find and thanks for the write up!
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • blueapplesoda
      • Dec 2005
      • 1904
      Never thought about using those stupid audio balance things. Maybe you should put a amber gel coat and transparency over it, so it looks more OEM. Sweet.
      • evilnickwong
        • Aug 2007
        • 302
        I see you are getting power/reading from the purple/white radio ACC wire. Does that give a reading of 14+V when the car is running?
        I took my voltmeter reading from the ACC wire which powers the glove light and it doesn't show the 14+ charging voltage. It's also affected by brake or signal lights. :-/
        • george graves
          • 20003
          Although that is a cool little voltmeter, it's not designed to survive in a nasty automotive electrical environment. So, I hope you aren't too upset if it fails on you. I doubt it would catch fire or something. Most likely it will just stop working.
          Originally posted by Matt-B
          • Atlant
            • Feb 2012
            • 63
            Yea. Soon I plan on taking it back out and putting in something between the display and panel (I was thinking a piece of a ginger ale bottle)
            I was also not to happy with the finish so I plan on spraying it with satin black from a farther distance to try to match the surface. Thanks to (Forced_Firebird) for the tip.
            Yes It reads 14 volts when the car is running.
            I sort of assumed this. but thanks for the heads up. Ill be putting one of your narrow band gauges that will last a lifetime next to it very soon :)
            • Jszy25
              • 352
              Interesting...think I may do something similar seeing as how I've just replaced my battery and alternator. Good to keep an eye on things.
              91' 318is - OBDI M52/ZF swap w/ S50 cams
              • evilnickwong
                • Aug 2007
                • 302
                Whoops, just saw you replied.
                Does it jump up and down when you use the signal lights? I would assume the ACC powering the radio is the same as the ACC powering the glove box light, or am I wrong here? Thanks. :)
                • bernzpeed
                  • 3917
                  great idea but i wish it was amber though
                  89 E30 S52
                  Transaction Feedback.
                  • Ryann
                    • 3350
                    It's $7.95 with numbers on it.
                    • george graves
                      • 20003
                      Yep - I know that - It just so happens that I work for the company that sells it - what's up? ;)
                      • Atlant
                        • Feb 2012
                        • 63
                        That's what inspired me to start doing more EE stuff read your blog thingy and decided that having Arduino sit unused for almost a year was a crime.
                        • iwantspeed
                          • 3164
                          I made a digital volt meter.
                          Credit is goes to Atlant, I just tweaked his idea.
                          And George graves idea on the light output of the plastic.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • bernzpeed
                            • 3917
                            awesome! now that's what I'm talking about.
                            89 E30 S52
                            • george graves
                              • 20003
                              Good job! Hope you at least added a fuse - I would be the least you can do to keep that thing safe encase it blows w/o any real input protection.
