The Detailed E30 R-134a Conversion Thread/DIY
Originally posted by colton135 View PostIf you can track it down R-414b, dupont came out with a direct swap for R-22. You dont need to change the condenser, evaporator, metering device or the compressor. Im running it right now and it works great.
or this stuff http://www.redtek.ca/
Originally posted by 997_rich View PostOk, I've got a High+low pressure switch in one housing from an E36. Pic attached here. Which connector is the high switch and which one is the low switch?
Thanks
