DIY: Hydraulic Handbrake Install
  • FLG
    • Sep 2011
    • 3165
    #31
    Any further back and you'll have issues pulling it... Maybe a push one would be better.
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • ROLLingKING
      • Apr 2011
      • 1169
      #32
      Originally posted by IronFreak
      Got ya, not three or 4 weeks ago I was talking about his with my buddies but they didn't think it would work.
      As long as it doesn't effect my brake bias with the pedals this will be in my car!! Great write up man!
      pretty much?lol so what happens if u pull the ebrake while on the foot brake..does the rear lock up?
      and also, now that uve had it installed for a couple months does it effect rear braking now that it is also being used for hydro.
      and thanks for the write up. im going to be doing this in a couple weeks for sure
      m20 is plenty. im simply a drifter.
      build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
      • Mr. Horsepower
        • 386
        #33
        Another way.
        This is how I made my hydraulic handbrake setup.
        1987 BMW E30 M3 RB26
        2016 VW Polo 1.2 TSI R-Line
        Originally posted by 5spoke
        Fucking norway and your sick clean ass e30's! Yes i am yelling!
        • MaxBell
          • 1390
          #34
          ^^ This setup took the rear brakes away from the the foot pedal I guess?
          REMEMBER: Be safe and have fun is Rule Number 1.
          The Epic Unbuild of Clint Eastwood
          • Mr. Horsepower
            • 386
            #35
            No, what makes you think that?
            • ROLLingKING
              • Apr 2011
              • 1169
              #36
              so doing this kind of set up does waffleswaffleswaffleswaffles with your regular braking?
              • FLG
                • Sep 2011
                • 3165
                #37
                No reg braking is not affected. Unless to try to pull the e brake and break at the same time.
                • ROLLingKING
                  • Apr 2011
                  • 1169
                  #38
                  right..so if youre on ebrake and have to slow the front also, which happens in the rain often, then what!?
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    #39
                    does the front then get a whoole lot of brake pressure and lock em up? im trying to hear how its affected. id like to daily this set up but not if its sketchy. Maybe thats what the bias is for, i guess i need a better explanation other than its affected or not affected
                    • Jezza
                      • 222
                      #40
                      The foot brake would be the same, when you go for the hand brake it will be pressurized so it wont really move
                      E-9 Motorsports
                      Supported by:
                      Insane Innovations LLC
                      DTMFiberwerkz
                      Achilles Radial
                      • Jezza
                        • 222
                        #41
                        Or if you handbrake first, then go for the foot brake, the handbrake will fight to go back to its neutral position.
                        E-9 Motorsports
                        Supported by:
                        DTMFiberwerkz
                        Achilles Radial
                        • FLG
                          • Sep 2011
                          • 3165
                          #42
                          None of these setups removes any braking abilities during normal braking.
                          The only time you will have an issue is if you try to e-brake and hit the brakes (your fighting one with the other) or if as Jezza said, you go right for the brakes after applying the e brake, though its hasnt been an issue whatsoever.
                          • jalopi
                            • 2370
                            #43
                            Originally posted by Mr. Horsepower
                            I really, really like this. Can't really tell if you kept the ratchet lock, but it does look like you can keep the regular cables.... definitely will be on my mind when I'm doing my hydro setup. Also, how thick is that metal you used for the bracket? 1/8"?
                            • Mr. Horsepower
                              • 386
                              #44
                              I'm very happy the way it turned out. The lock is fully intact, but one need to keep in mind that hot fluid does shrink when it get cold (pressure will fall). So if I park in a hill, I always pull some clicks extra after it hangs.
                              It is possible to still use the cables, but I have E36M3 rear brakes. So this was a win win option for me in order to keep the handbrake and also get something that locks the rear wheels easy.
                              • jalopi
                                • 2370
                                #45
                                Huh. So are you happy with the length of the stock e-brake for ease of lockup? I'm thinking I'll make some sort of clamp-on extension bar so I'd work like an aftermarket e-brake for the track.
