Dont know if its been covered but can I use the E36 tie rods? I have a E36 M3 rack with the tie rods on still and if I can will just use them.
How To Guide - E36 Steering Rack Swap
yes you sure can. just did my swap this weekend. man what a pia but all in all i'd say it was worth it considering i have $45 invested. :)Comment
Build, break, repair, repeat.
91 300zx TT
03 540i Msport
91 318is track
89 Isuzu Imark/lotus 24hr Lemons car
Originally posted by george gravesR3v is a very different kind of forum - don't come here with your bull shit - we'll actually take the time to call you on it.Comment
Why do I need to purchase 85 dollars in new hoses when they are all already there?
Is ee the point in the new reservoir (filter replacement) but I don't see the point of the new hoses. Trying to save some money here.Originally posted by z31maniacI just hate everyone.
No need for discretion.Comment
all i bought was rack $38 from the junkyard, about $10 in hardware from lowes, new resevoir $20 and a good bit of time & frustration. I reused my e30 pressure hose turned around although it was hard to put in the banjo bolt because of the angle.Comment
You don't. I reused my hoses and just replaced the reservoir. Also I don't know why anyone would spend good money for the bits and pieces to do the swap when washers are so cheap at the hardware store.Comment
My dremel isn't working. So I handsawed off the rivets that hold the two pieces of the steering rack together. They will spin but they won't slide out. What gives?
Edit, I got it. Just had to drill them out more. Since I didn't grind them they were just holding on barely I guess.
Now I need to drill the hole larger anyways for the 7/16 bolt. Which seems to be the same as a trans bolt that I had laying around in a box. :)Last edited by 87e30; 07-21-2009, 06:56 PM.Originally posted by z31maniacI just hate everyone.
Just a warning to those doing the swap...
I used a 95 M3 rack. Swapped it in about 3 years ago. I got new tie rods for it as well. The locking plate notch on the M3 rack was different, and I knew when I bent it into place it wasn't going to do much. Sure enough, 3 years later, the inner tie rod came loose from the steering rack. It QUICKLY spun out (within 2-3 days of when it began coming loose, it was already near the end of the threads). If that would have came out completely, I'd probably be dead.
If you notice alignment or tire wear problems, don't just readjust your outer tie rods to correct the toe-out. Make sure the inner tie rod hasn't come loose.Comment
Well, this is from memory from three years ago, and there's been engine swaps, tranny swaps, etc.. in between then and now, so I'm not 100% sure what rods and lock plates I used, but I do know it all was new.
The M3 rack does have the notch for the plate to sit into, but the inner tie rods were too big for the lock plate to bend over. Look at this pic:
Where you are supposed to bend the tab over... either my plate was too small or the tie rod was bigger then normal, because I couldn't bend mine over like that. I could only get a very small bit of the edge to fold over.Comment
