How To Guide - E36 Steering Rack Swap
  • jeffnhiscars
    • Jun 2011
    • 6011
    #811
    FYI AKG has the e30>e36 rack adaptor kit on sale for $20@. I got 2 to my door for $45.75 shipped
    Alice the Time Capsule
    • Qik-BMW
      • Jan 2013
      • 32
      #812
      Please Help
      Hey guys, I am trying to do this swap to my 1985 grey market 320i with Manuel steering non airbag. The problem I am having is finding a steering shaft that looks like the op's. I have had BMW fax me pictures and they find no steering shaft that looks like the ones on here that you install the spacers on which I think are non airbag shafts. BMW tells me that all e30 s 1985 and up have airbag. If anyone has one for sale or has a part #, or any other idea, please let me know.
      Thanks in advance.
      • Qik-BMW
        • Jan 2013
        • 32
        #813
        Originally posted by Jim Lepage
        I did the same setup than chrisnxl185.
        Someone please give me the part# to this steering shaft, or if anyone has a used one for sale. I need one ASAP.
        Thanks
        • jeffnhiscars
          • Jun 2011
          • 6011
          #814
          Ive done 2 swaps in the last 18 months (about to do a 3rd) on an 84, 87 & 89 (all non airbag) and thats the exact same knuckle on all of them. Go to a junk yard or post in the WTB section for a non airbag knuckle and you'll get one. The knuckle adaptor kit is about $25
          You really do not want to know what a dealer is going to charge you for a new one.
          • Qik-BMW
            • Jan 2013
            • 32
            #815
            I have all the parts and the adapter kit. Just need the steering shaft. I posted in the wtb last night and nothing as of yet. I figured out that BMW has redesigned the steering shaft, so a new one will not work
            • jeffnhiscars
              • Jun 2011
              • 6011
              #816
              Have you checked the local bone yards ?
              PS Ive asked a buddy of mine if he has one and will PM you if he does.
              • Klug
                • Sep 2011
                • 804
                #817
                So i've searched this thread and google for quite a bit now. I cannot for the life of me remove the knuckle from the steering shaft. I have the split in the knuckle spread apart as much as possible and cannot seem to get it to drop. What techniques have you guys tried?
                Also tried a slide hammer setup on the rack end but it only puts stress on the guibo.
                555Garage - Kingston, PA
                '13 BMW e70 X5 35d
                '95 BMW e34 525i
                '92 BMW e30 325i S52 Vert (Quade the Vert)
                '92 Range Rover Classic
                '90 Range Rover Classic
                '89 BMW e30 325i Coupe (The DIRTY30)
                '81 VW MK1 Rabbit Caddy Diesel
                '76 Honda CB550K Cafe/Brat
                '67 Pontiac LeMans
                '24 Model T Depot Hack
                ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  #818
                  You have to completely remove the bolt from the rack end as it locks in to a grove on the pinion shaft
                  • Klug
                    • Sep 2011
                    • 804
                    #819
                    Already removed the 13mm bolt from the end that clamps it down on the grooves
                    '13 BMW e70 X5 35d
                    '95 BMW e34 525i
                    '67 Pontiac LeMans
                    • ridingsupreme
                      • Apr 2009
                      • 26
                      #820
                      Sorry if this has been covered, sorry in advance for being a newb. I live by not fixing things that aren't broken. So my question is for a z3 rack conversion on my e30 do I really need to place all the ps hoses with the new rack? My originals are surprisingly still in great shape but the rack has taken a dump. I got lucky and got a granny's garage car. Only 134k on the dash. My theory is that a tighter ratio rack would have high hydraulic pressure requiring new lines but I'm a newb and not quite sure. Don't want to replace parts that still work fine.
                      I'm hoping to get away with merely swapping racks and modifying the steering knuckle. And obviously changing the fluid
                      • Klug
                        • Sep 2011
                        • 804
                        #821
                        Just a follow up, ended up using the tie-rod separator to get it to wedge itself off...what a pain in the neck...now I can't wait to slide the thing back on...ugh
                        btw, There isn't any finished knuckle pictures of e30tech's hardware kit, so here's my finished product.
                        '13 BMW e70 X5 35d
                        '95 BMW e34 525i
                        '67 Pontiac LeMans
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          #822
                          You will need to grind off the corners of the yokes so they will take a sharper angle without binding. The e30tech DIY should have pics of what to remove
                          • Klug
                            • Sep 2011
                            • 804
                            #823
                            Thanks! I wasn't aware I needed to do that.
                            Just incase any one here in the future needs to know. Grind so that its rounded out and it loses the squared end. The second arrow area (at the 3 o'clock position) should be grounded down by a few MMs as well.
                            '13 BMW e70 X5 35d
                            '95 BMW e34 525i
                            '67 Pontiac LeMans
                            • cormier
                              • 380
                              #824
                              Hmmm-- how sharp are your angles? I feel like mines pressed so far onto either side that the angle isn't that bad at all
                              • ridingsupreme
                                • Apr 2009
                                • 26
                                #825
                                Was my question too stupid? Lol come on humor me please.
