How To Guide - E36 Steering Rack Swap
I think he's talking of installing the knuckle in halves to each of the shafts, then bolting the knuckle together... I suppose it could work, but I'd be very nervous about not being able to adequately torque the two halves together.Comment
Yes, I wa thinking of installing in halves. I removed my intake boot and have good access to them both. I was thinking this because I was worried I was not getting the knuckles firmly on the shafts.I love that people ask stupid questions so I dont have.Comment
I needed the spacers for my z3 rack install to my 92 e30 non airbag cabby.2001 silver/Blk 325 cabby. SOLDOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leatherComment
I've now just used 2 spacers and bolted up the knuckle, I just don't understand why I had to do it this way.
Like most of my projects Im concerned I did something wrong and will have to do it all over again in a day or two.I love that people ask stupid questions so I dont have.Comment
It sure looks like you slide the lower knuckle too far onto the spline... There is a little groove that you should line up with the bolt hole. Did you push it on past the groove to the point of going past the splines on the shaft??
There is no such groove up top, but be sure you didn't slide up so far that the firewall and upper knuckle ever come in contact.Comment
2010 F650gs twin
What would be the negative to having the knuckle to far down on the rack spline?It sure looks like you slide the lower knuckle too far onto the spline... There is a little groove that you should line up with the bolt hole. Did you push it on past the groove to the point of going past the splines on the shaft??
There is no such groove up top, but be sure you didn't slide up so far that the firewall and upper knuckle ever come in contact.I love that people ask stupid questions so I dont have.Comment
So long as the spline isn't hitting the u-joint, nothing. Some people use that method to avoid having to space the knuckle. My only caution to you would be to leave the knuckle ends loose, until you fully torque the knuckle halves together.Comment
The knuckle needs to be in the right spot for the bolts to be able to pass thru to tighten the half's in the splines.
Sent from my Galaxy Nexus using Tapatalk 2Comment
trying to get set up for a swap. Went to bma.com to try and find the spacers you got and it said they were unavailable. I guess i can just make something up but it would be cool to have them in hand especially at the price you got them for. I plan on using my e30 inner and outer tie rods on the e36 rack as they are in better shape. Great thread by the way!Comment
