How To Guide - E36 Steering Rack Swap
  • KVF
    • 297
    #886
    You can pick up correctly sized spacers at Home Depot on the cheap.
    • mccor023
      • Jul 2011
      • 683
      #887
      Just curious to see what toe others have gotten post swap and alignment.
      After mine yesterday I am at LF-.14; RF-.15 for total toe .29
      I'm still trying to figure out the math behind my rear toe getting worse from .11 (b/f) and now .14 total toe.
      I love that people ask stupid questions so I dont have.
      • Northern
        • 5046
        #888
        Should have whatever toe it was aligned to?
        Originally posted by priapism
        Originally posted by shameson
        • FLG
          • Sep 2011
          • 3165
          #889
          I just had my bud zero the toe.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • mccor023
            • Jul 2011
            • 683
            #890
            Thats what I asked for, and shop said they couldnt get it any closer.
            • FLG
              • Sep 2011
              • 3165
              #891
              New outer tie rods?
              • mccor023
                • Jul 2011
                • 683
                #892
                New outer tie rods?
                New inner/ outer. Rebuilt maval, new m3 offset cabs, new st sway w new end links. I could go on, but.
                • FLG
                  • Sep 2011
                  • 3165
                  #893
                  Hmm not doubting the shop but is it possible they simply were lazy and didn't Wana keep playing with it? It took us just a bit to dial it in perfectly.
                  • dsphil
                    • 495
                    #894
                    I'm in the process of doing the z3 rack swap. I got a hold of the oe bmw z3 rack, part #1 092 031. not the zf. I notice that this z3 rack doesn't have the notch for the locking plate for the tie rod assembly. Is this suppose to be torqued down or use some other locking plates that I am not aware of?
                    327is
                    325es
                    325es
                    318is
                    Fiesta ST
                    E46 M3
                    • RobertK
                      Kicked cancer's ASS.
                      • Jun 2005
                      • 5864
                      #895
                      I've not install a Z3 1.9l rack yet but I would at least use a little blue locktite.
                      • JinormusJ
                        • 6887
                        #896
                        Have the Z3 rack; a little annoyed it doesn't have lock-plates, but eh..
                        I ended up just using red Loctite on my knuckle; wanted to make sure that junk doesn't come off
                        My only thing I'm scared about is that I ended up using the same red Loctite on my inner-tie rod. Hopefully I never have to remove it haha
                        Ended up doing on a non-airbag car
                        To further add; since there is much less info on the Z3 rack:
                        I HAD to buy spacers to be safe; using AKG's knuckle spacers ensure that you can use the knuckle lining notch on the rack spline to insert the locking-bolt. If you want to grind down your bolt, you don't have to buy the spacers. I am getting binding, so I suggest grinding down an rounding off the squared off U-joint parts; what I will be planning on doing once my car is back on the lift.
                        BOTH e30 power steering hose fit easy; all I had to do was give it a 45* bend in the HP line so that it was a perfect 90* so it would actually mount. Once I mounted it, I again bent it up, out of the way of the knuckle. The second e30 hose fit fine. Both hoses fit snuggly over the engine mount, like it does with the e30 rack, not in front of it
                        Ended up using e36 (actually z3, but they are essentially the same) tie rods. Fit the struts no problem
                        I mounted my spacers above the rack, but I am hearing people mounting them below to combat bump steer; I will be swapping them shortly after my little bugs are troubleshooted
                        • joncrz
                          • Jul 2013
                          • 364
                          #897
                          where specifically and how would I find it ?
                          My don't quote me list:
                          I could be wrong, but I don't think it's a smog test type of thing. IIRC think it's against CA law to *sell* a dual outlet muffler as a replacement for a car that came from the factory with a single. But don't quote me on that.
                          • ELVA164
                            • 4861
                            #898
                            I don't have any personal experience with it, but this sounds like a good argument for putting spacers on top:
                            • JinormusJ
                              • 6887
                              #899
                              I ended up having little to almost no bump-steer having them mounted up top.
                              The fat lazy guy in me just left it since it doesn't seem to be harming anything
                              • FLG
                                • Sep 2011
                                • 3165
                                #900
                                Above for me, no bump steer
                                Sent from my SCH-I545 using Tapatalk 2
