How To Guide - E36 Steering Rack Swap
  • jrobie79
    • Mar 2006
    • 2526
    #991
    yep
    Originally posted by Luke318is
    didnt have time to order any hardware, so im going to be making a trip to the hardware store!!
    which step uses these?
    Bolt M10x50 - - - - - - - - - 26111226737 - - - - x2 - - -$2.70
    is it step 24, bolting the rack back onto the subframe with the short spacers?
    1991 318i ---- 308K - retired
    • Haystack
      • Mar 2014
      • 213
      #992
      Just a tip I learned today.. E36 rack, IE steering guibo. Akg kit. I was having a hell of a time getting my knuckle back on the spline. Engine in the car.
      I'm by myself.. I stuck a flat head to slightly open the spines on the knuckle, wiggled it on about a quarter of an inch. Once it was on there and straight, I didn't want to use a BFH or block of wood against the entire rack. I figured any sort of force would be absorbed through the guibo or the rest of the knuckle. I removed the drivers side motor mount arm, then grabbed the handle of my jack.
      Coated the end of the spline with antisieze, Set the handle right against the knuckle that needed to slide on and gave it a few wacks. Went right on easily. Slid the bolt through the subframe tabs and spacer, no adjustment needed. Once it goes in as far as it can, the holes line up.
      • MC Hammered
        • Jul 2008
        • 2076
        #993
        Has anyone else compared the feel between an e36 vs e46 rack?
        I have both and find the e46 rack feels heavier to turn compared to the e36 rack, so I am wondering if the e46 rack is supposed to feel this way or not when driving.
        My 1989 e30 s52 Touring... this is Betty
        My 1989 325i vert (sold)...this is Nina
        My 1991 M5 (sold)... this is Veronica
        Photo comparison: OEM vs aftermarket windscreen for a convertible
        • JinormusJ
          • 6887
          #994
          The rack has a larger ratio; if you want to maintain a softer feel as you upgrade your rack, you have to upgrade your power-steering pump aswell.
          • MC Hammered
            • Jul 2008
            • 2076
            #995
            I was not wanting to match the e36 softer feel, I wanted to confirm the e46 rack feels heavier as I prefer it.
            • the imitator
              • May 2013
              • 1006
              #996
              If I want a heavier feel in my z3 rack, couldn't one possibly find a larger diameter pulley, thus less pressure, giving a heavier feel.
              • Wanganstyle
                • 2828
                #997
                to confirm your thoughts
                I put a e46m rack in my e36m. It's heavier feeling with e36m pump and I like the heavier feeling.
                • JPM_MRED_
                  • Jul 2014
                  • 19
                  #998
                  I think you would need to change the pressure relief spring to make a big notice. At nearly anything over idle, a lot of fluid is recirculated through that pressure relief valve...
                  • iwantspeed
                    • 3164
                    #999
                    I made a small batch of e36 steering rack spacers
                    send me a pm if interested
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • CLM21
                      • Dec 2013
                      • 223
                      #1000
                      Where is everyone picking up their e36 racks from? Went on bmaparts looking for one, and its very ambiguous.
                      http://www.bmaparts.com/ShopByVehicl...e+Unit&mode=PA
                      Looks like they have 2 Z3 maval rebuilt racks that are the exact same for different prices?? Confusing....
                      • the imitator
                        • May 2013
                        • 1006
                        #1001
                        I surf multiple bmw sites along with ebay, and request parts numbers through messages.
                        • JinormusJ
                          • 6887
                          #1002
                          I doubt it
                          This is still a pretty popular upgrade
                          I bought mine from AKG
                          Full Service BMW & MINI Repair in Alpharetta, GA, Specializing in Sport Upgrades, Performance, Oil Changes, Brakes, AC, Transmission & More!
                          • CLM21
                            • Dec 2013
                            • 223
                            #1003
                            Doesnt e30tech also sell spacers?
                            • SterlingMetE30
                              • Mar 2014
                              • 229
                              #1004
                              Item - BMW Part Number - Qty - Price[/b][/u]
                              7/16 Bolt 2 Inches Long - - xxxxxxxxxxxx - - - - -x2 - - -$???
                              Bolt M10x50 - - - - - - - - - 26111226737 - - - - - x2 - - -$2.70
                              Copper Seals 14x20 - - - - -32411093596 - - - - -x4 - - -$0.68
                              Copper Seals 16x22 - - - - -32411093597 - - - - -x4 - - -$1.04
                              Power Steering Res. - - - - -32411097164 - - - - x1 - - -$19.50
                              High Pres. PS Hose - - - - - 32411141953 - - - - -x1 - - -$74.00
                              Nut - - - - - - - - - - - - - -72111977925 - - - - -x2 - - -$1.10
                              LP PS Return Hoses - - - - - xxxxxxxxxxx - - - - - x2 - - -$14.50
                              Do all of these parts need to be replaced? Just a curiosity.
                              • Kevinl
                                • Oct 2012
                                • 897
                                #1005
                                So I am going to order the akg rack spacers should I get a poly steering guibo or not
                                1989 BMW 325is Lachsilber metallic 5 speed
                                2007 BMW 335i KARMESINROT 6 Speed manual
                                2011 BMW X5 35I
