How To Guide - E36 Steering Rack Swap
  • AwakenNoMore
    • Dec 2010
    • 1291
    #1006
    Yes or buy the Ireland Engineering version for less $$
    1991 325i - "Scambles" The Daily Driven lightly modded.
    1988 Mazda RX-7 TII "Mako" The Free Dorito
    bacon by Jared Laabs, on Flickr
    • E30NJ
      • Aug 2013
      • 921
      #1007
      I did this, hands down the best mod i've done so far.
      • Kevinl
        • Oct 2012
        • 897
        #1008
        I thought the IE one didnt fit right or something
        1989 BMW 325is Lachsilber metallic 5 speed
        2007 BMW 335i KARMESINROT 6 Speed manual
        2011 BMW X5 35I
        • AwakenNoMore
          • Dec 2010
          • 1291
          #1009
          I haven't heard this info.
          • efficient
            • Feb 2012
            • 3312
            #1010
            My Ireland engineering steering guibo fits good. The first version is thinner then the newer updated poly guibo, new home fits fine
            • e30lyf
              • May 2007
              • 4548
              #1011
              i just got my e36 rack w/ e30 inner tie rod (remanufactured) and AKG spacer.
              anyone can chime in what tie rod i need to use? i have e30 M3 5lug swap the stock e30 it's long about 2". thank you
              - Fercy -
              Classic BMW Specialists
              Santa Clarita, CA
              www.BimmerHeads.com
              • 3vilE30
                • Jan 2013
                • 344
                #1012
                E30 inner matches up with E30 outer
                E36 tie rods are female while E30 rods are male
                You can't interchange the two
                • SkiFree
                  • Jun 2011
                  • 2766
                  #1013
                  That's because it's a load of hooey. Haven't found one to be an issue stemming beyond issues stemming from a lack of understanding.
                  ADAMS Autosport
                  • BruceJ
                    • Sep 2012
                    • 62
                    #1014
                    Thanks for the writeup, just finished this mod. Its GREAT!!!!I installed a smaller diameter steering wheel at the same time and I luv it. I ordered a standard e36 rack but ended up with a 2.7 ratio.
                    No complaints. Pretty straightforward.
                    NOTES:
                    1. PAY attention to the HP hose install pic for orientation. Obviously it goes from pump to steering rack. It needed very little bending to attach to the rack in my case. Just enough so that the hose does not contact the engine block.
                    2. Otherwise regarding the HP hose to pump connection, once you have it fully threaded, rotate the hose so again it does not touch other hoses or anything else, then tighten it.
                    3. LP hoses - They have two different diameters. THE BIGGER diameter of the two goes to the Pump.
                    4. Tie rods re-install - tighten to 48 Ft-lbs.
                    5. Alignment - just get over it and spend the money to get it done immediately. It shouldn't take a competent mech more than 30 min and is well spent.
                    89 e30 white vert
                    88 e30 Red vert
                    2003 330i sedan
                    2011 E93 335is
                    2007 Z4Si (gone)
                    • ascendotuum
                      • Jul 2013
                      • 80
                      #1015
                      So I have an M52 swapped E30 and the steering rack is bad. Will I still be able to swap any of these racks into it or does the M52 change things?
                      • DasTaco
                        • Sep 2013
                        • 43
                        #1016
                        Did this to my s52 swapped e30 so you should be fine.
                        • ascendotuum
                          • Jul 2013
                          • 80
                          #1017
                          Looking for some help to make sure I order the right parts. Here's what I ordered so far:
                          the rack itself
                          AKG spacer kit
                          polyurethane flex disc
                          I think I just need the fluid, high & low pressure hoses, reservoir, and of course the tacos. Can anyone confirm? Thanks.
                          • not_a_kiwi
                            • Jan 2014
                            • 35
                            #1018
                            the rack itself
                            AKG spacer kit
                            Yeah basically make sure you get the washers for the banjo bolts. Is your car non air bag?
                            • not_a_kiwi
                              • Jan 2014
                              • 35
                              #1019
                              Which rack did you get? What tie rods will you be using?
                              • ascendotuum
                                • Jul 2013
                                • 80
                                #1020
                                Yes it is non airbag. I got all that and the copper seals as well. Thanks bro
