DIY-Independent Fogs with highs as well
  • SchnellerVert
    • Sep 2005
    • 3948
    Euro cars have a funky three prong adapter that goes in the blank area.
    • Schnell_e30
      • Aug 2007
      • 4
      I have to say, this was one of the easiest mod's I've done on my e30! Thankyou for the information Spinning Tires!! For anyone who is wondering about this, dont be intimidated its really simple.
      Originally posted by Spinning Tires
      take out the one relay and take out the three screws
      then break the connection on the circuit board with a screw driver or a utility knife. solder a wire to the spot right next to the break you just made. in my case i used a grey wire. this connection is located directly opposite the side where the relay was removed to get the screw out in step one
      Last, connect it to the parking light wire which runs through the inside of the fuse box. you can use a test light for this or just see what color wire is going into your parking light.
      • So Live
        • 2512
        i was about to say you guys are pretty G-code till i saw spinning tires's post. thanks for putting up a more "correct" way to do it.
        all this wrapping wires around relay posts to other relays lolz
        While your in the fuse box, you should get the high beam and fog light indicators (in the dash board) to dim with the rest of the lights. that would be tits
        ...Looks like i have a project for saturday :) tomoro will be reading the diagrams
        -Chris
        • bignate948
          • Apr 2006
          • 542
          i have been wanting to do this for a long time and i have some time this weekend so i think that ill try this.
          • banndit
            • 62
            can't you just run the power wire to the fog light switch from the parking light feed at the headlight switch? Its a low power circuit and it would power the fog lights anytime the parking lights are on.
            B
            • franco90
              • 3185
              B
              why?....
              I've always been proud of being a Marine.
              I won't hesitate to defend the Corps
              "Supersquad"
              ‎"Prostitutes are a sub-category of Amusement Parks"-
              • banndit
                • 62
                Originally posted by franco90
                why?....
                oh, I dunno, so you can use two scotch loks and about 3" of wire instead of drilling holes in circuit boards and or relays in a not really foolproof way in a non-waterproof environment?
                :shrug:
                B
                • DaveSmed
                  • Apr 2007
                  • 1406
                  :shrug:
                  B
                  Scotch locks are the work of satan for one, and two, soldering to a circuit board that has other connections soldered to it to have the current flow and circuitry match what would be the OEM way of doing it (if the car was set up that way factory) is much cleaner.
                  Besides, that doesn't solve the fact the relay simply doesn't get power unless the headlights are on. Gotta get the power to it, gotta be in that fuse box.
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
                  • banndit
                    • 62
                    I'm *always* willing to learn something, so if I'm wrong, great!, but follow my logic here. The parking lights always have power at the headlight switch. The low beams don't have power unless the key is on. Same with the high beams (via the headlight switch and relays).
                    Logic would then say that if you wanted the driving lights to have power any time the parking lights are on (parking lights, low beam, or high beam) that the "easiest way" would be to tap the output from the headlight switch to the parking lights and run it to the input to the fog light switch. You would want to cut the current input to the foglight switch to prevent feedbadk to the other lights. Scotch loks are ok in a dry environment, but you could solder/ heatshrink to be more electrically sound.
                    B
                    • DaveSmed
                      • Apr 2007
                      • 1406
                      B
                      Good in theory, but they wired these cars a little strange as far as lighting goes. Are you familiar with how a relay works? Its basically an electrically controlled switch. Well, the button on the dash supplies a ground to the coil of the relay (the part that actuates the switch) to control the fog lights.
                      The ground wire on the button only has a ground to give the relay IF the headlight switch is pulled all the way out. It isn't as easy as splicing into the parking light wire as the parking lights are positive side switched. You would be tapping into a plus where you need a minus.
                      The other problem is the positive side of the coil.... It's connected directly to where the low beam headlights get their power from, if there not on, theres no positive to the coil. That part is all in the fuse box.
                      Oh, they changed all of this for late model cars, more stuff is powered from different stuff in the fuse box.
                      And scotch locks still suck, overheating corroding pieces of junk.
                      -Dave
                      • banndit
                        • 62
                        this is great info. When did they change the wiring from the fog light switch proving a ground to the fog light switch powering the relay?
                        B
                        • DaveSmed
                          • Apr 2007
                          • 1406
                          B
                          I'm not sure when the break in the production date is, but going by late model/early model bumpers and taillights is usually pretty close.
                          I described a early model, late models have a ground at the fog light button from the headlight switch in either park or head positions (Good news right?) but they get weird at the fuse box. The high beam relay has to be in the off position for power to go to the coil of the relay. (still so far, so good) but the power to the switch portion of the relay itself comes from the low beam headlights.
                          -Dave
                          • banndit
                            • 62
                            mine's an '89 (and '91). I'll get out the meter and play with these circuits later.
                            B
                            • Cessna88
                              • May 2008
                              • 15
                              I have an 89 325i and this is what I did:
                              I soldered pins 30 and 87 together on the low beam relay which allows me to leave my fog lights on with the car ignition off when the light switch is on.
                              I also soldered pins 30 and 87a together on the high beam relay which allows me to leave my fog lights on with the high beams on.
                              I still cant drive with just my fog lights on. Someone correct me if I am wrong on this but it looks like the fog light relay gets its power from the low beam relay. In order to run the fog lights with only the parking lights on the fogs would need to get their power from the parking light wiring and would not just flip the relay.
                              • Rocla
                                • 922
                                a 30-87 jump makes relay useless. you could just use jumper wire.
                                Unless the indicator lamps on dash require relay to be pulled.
                                Current:
                                BMW 320i 2d 2.0 m20 -88
                                BMW 325i Cabriolet 2.5 m50 -88
                                BMW 316i touring 1.6 m40 -90
                                BMW 320i 4d 2,2 m54 -01
