DIY-Independent Fogs with highs as well
  • NC325iC
    • Mar 2004
    • 6565
    high beam write up is not quite ready yet, i need to double check a few things.
    This writeup was derived using basic knowledge and some help from
    but is more general
    Do this at your own risk, I do not take responsibility for anything you screw up.
    Alright this writeup will tell you how you can make your fogs stay on with parking lights and even high beams.
    Needed:
    -about 6 inches of wire (wont need it all but have enough incase you screw up)
    -flat head screw driver
    -MULTI METER (crucial as this write-up does not tell you exactly which leads to cross)
    -Drill and small bit/ soldering
    This will work for all cars (as far as I know)
    First locate your fog light relay (on my car it was k8 ) remove it, the flat head screwdriver is very useful for this.
    Next use the screwdriver to pry you your low beam relay, and might as well go ahead and take out that high beam relay too.
    PARKING LIGHTS
    Alright now that we have all of the relays out go ahead and set your multi meter to dc 12ish volts, turn on your low beams(don’t forget to turn the ignition to on) ok now using a GOOD ground probe each of the terminals where the low beam relay was until you find 12v. Then you can go ahead and turn off the lights and the ignition to save your battery.
    Alright now that we have our 12v source we can figure out what to hook it to, set your multi meter to continuity and check the remaining terminals of your low beam relay with the terminals for your fog light fuse, ie. Check each low beam terminal for continuity to each of the fog light terminals. Once you find one with continuity then you can turn off the multi meter and pull out your drill, with a very small bit just big enough to fit your wire through the hole it makes.
    (Not needed if you’re going to solder)Alright take your low beam relay and drill a hole in the prong of the 12v source close to the top then drill a hole in the prong that has continuity to the fog lights again near the top, by top I mean near the box part of the relay.
    Alright now that you have the holes ready strip one end of the wire enough to get through the hole and wrap most of the way around the prong. Now making sure you have enough length to make it to the other prong cut the wire and strip the other end and thread it through like you did the first one. Now replace the relay making sure not to put too much pressure down on the relay or it might short the leads inside the relay.
    Now test to check and see if your fogs come on with the parking lights (this requires you put the fog relay back in, do it loosely if you want to do the high beam mod as it’ll have to come back out)
  • moatilliatta
    • 6144
    thanks dude. I just took some stuff apart today wondering how to get started one this. perfect timing dude. I'll post some pics once ive finish.
    @Zakspeed_US
    • tjmonsen5
      • Jan 2006
      • 232
      my cars fogs, highs, and lows can all stay on together. Is this because its a euro model? or did my previous owner already do the wiring?
      • NC325iC
        • Mar 2004
        • 6565
        no clue, but i can do that to cause im amazing
        • moatilliatta
          • 6144
          This kid dont lie.
          @Zakspeed_US
          • s52e368
            • 539
            i didnt see the part on how to keep them on with highs, did i miss it ?
            • NC325iC
              • Mar 2004
              • 6565
              nope, never got around to do ing it
              guess i should change the title
              basically you do the same thing as before but with the high beam and foglight relay (again do it at your own risk)
              • tabasco
                • Mar 2006
                • 861
                I connected the prongs 30 and 87a(center post on my car) to get the fogs to stay on with the high beams. Turned out cool.
                Jason
                • Spinning Tires
                  • Feb 2007
                  • 283
                  I did some modification to the back of the fuse block circuit board. It seemed much easier and it did both mods at the same time. No drilling required. I'll post pics later
                  First: 1984 318i
                  Second: 1987 325
                  Third: 1987 325is
                  Current: 1990 325i (Soon To Be 335i)
                  • Spinning Tires
                    • Feb 2007
                    • 283
                    take out the one relay and take out the three screws
                    then break the connection on the circuit board with a screw driver or a utility knife. solder a wire to the spot right next to the break you just made. in my case i used a grey wire. this connection is located directly opposite the side where the relay was removed to get the screw out in step one
                    Last, connect it to the parking light wire which runs through the inside of the fuse box. you can use a test light for this or just see what color wire is going into your parking light.
                    First: 1984 318i
                    Second: 1987 325
                    Third: 1987 325is
                    • Fidhle007
                      I can fly, motherfucker
                      • Oct 2005
                      • 7209
                      I already did the pin 30-pin 30 jump to keep my lows on with my highs (I have euro lamps.) This keeps my fogs on when my highs are on, can I still get them to come on with my parking lights or am I out of luck now?
                      '89 325is S50 Track Montser
                      '04 X5 Daily/Tow Vehicle
                      http://www.avarestoration.com
                      http://www.myspace.com/brendanfiddle
                      Click here if you want to be my zombie slave...
                      http://www.youtube.com/user/Fidhle007
                      • Spinning Tires
                        • Feb 2007
                        • 283
                        if you do it the way i pictured it would work. from the factory the fogs are run off the low beam circuit. this keeps them from coming on with the highs and parking. the way i did it hooks it up to the parking light circuit. and since all your doing is turning on a relay which requires very little power to do. you dont have to worry about popping any fuses
                        First: 1984 318i
                        Second: 1987 325
                        Third: 1987 325is
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          i dont understand where the grey wire originaly gets soldered to, could you better describe this please?
                          i had sealed beams originally, rewired for smileys, and jumped two relays (pin 30 and 30 from high and low beam relays), all 3 can be on, but i cant get my fogs to come on with just the parking lights on..
                          • Mr Deagle
                            • 1121
                            you guys are doing this the extremely hard way
                            • juscool
                              • Aug 2005
                              • 213
                              So which is the easy way ? I'm ready to rewire my lights.
