Sorry guys I didn't know this thread has been approved. I'll double check and get the exact measurements. Maybe the one I got was direct fit. But I am sure I ordered it from the same seller!
Digital Voltmeter for under 2$
I recently integrated the voltmeter into the check control panel. plug and play no external wiring.
It looks like this.
https://www.flickr.com/photos/408214.../in/datetaken/
327is
325es
325es
318is
Fiesta ST
E46 M3Comment
Looks awesomeI recently integrated the voltmeter into the check control panel. plug and play no external wiring.
It looks like this.
Couple more pics added. I may do a write up on this.
https://www.flickr.com/photos/408214...in/dateposted/
https://www.flickr.com/photos/408214...n/photostream/sigpic
327is
325es
325es
318is
Fiesta ST
E46 M3Comment
Yes, I meter it from the case. There are 3 manufactures for check panel. VDO, bosch, and hella. The hella is the easier to take apart. The VDO is lot more harder and the Bosch is almost impossible without breaking the face cover. The internals design is all different, but the harness is the same for all.sigpic
327is
325es
325es
318is
Fiesta ST
E46 M3Comment
Where did you buy the voltmeter that you used to do upgrade your check panel?I recently integrated the voltmeter into the check control panel. plug and play no external wiring.
It looks like this.
Could be better, could be worse.Comment
Any idea if this could be used as an ohm meter to monitor water temps from the factor water temp sensor? It should be 0-5k ohms resistance.
No one makes this car anymore. The government won't allow them, normal people won't buy them. So it's up to us: the freaks, the weirdos, the informed. To buy them, to appreciate them, and most importantly, to drive them.Comment
