Since you aren't going to be using it often, you could just twist the wires and not worry about it. I guess you could tin the ends with solder to keep them straight and clean, but I don't think it is necessary. I don't know of any end/connector that would be small enough to fit into the pin slots.
Turning Service lights off via jumper wire/diagnostic connector
honestly dont waste ur time fabbing up something extravagent.! i used a peice of speaker wire about 15 cm long cut it in half and duct taped a 5 amp fuse in the middle took 2 mins. thats right up is kinda sketchy tho its good but if you half the early style connector the illistration sucks i think i tryed 3 different pin combos befor i got the right one. its just they didnt really draw out the pins in the exact location. i dunno maybe its just me. it may take a while i had to turn the key on and off fo r like 2 mins and wait untill they flickdered and rest green . but after a couple of mins they all just reset back to normal oil servive and inspection back to red lights.
anyways that must mean i must replace the si batteries which makes me think i dont really want to special order them. for 13 dollars each. they say on the battery 1.2v AA but every AA i looked at are only 1.5V but i dunno had any one used like a deracel in it?????1988 e30 alpine white vert 5speed
1987 e30 325 eta
1983 e28 533
2001 x5 4.4l
1997 e36 M3 Alpine white 5speed
1991 Jeep XJ I6 4.0Comment
radio shack has the 23-149's for $8 a pair they are usually in stock.Comment
I had a local shop do it for me on my eta... since its the old school square plug. Thanks Ron Ager. :P:: PNW Crew ::
'87 325 4dr, '74 2002Comment
Originally posted by chileelkyamaze about the enthusiasm e30 generateComment
I have done mine that same way with a piece of wire for ages. Another thing I did was take a paint pen (yellow) and touch the area of the pins that I need to short on top of the diagnostic connector. It leaves a yellow dot on the appropriate pins. Then when its time to reset the service indicator lights I dont have to crack open my Bently repair manual and hunt down the pin numbers to jumper. Instead I just look for the two yellow dots! Works well and saves the hastle. Try it , you wont be disappointed!
anyone know how to do it on an older plug?97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Comment
