DIY Rebuilding green top injectors with video instructions.
  • iwantspeed
    • 3164
    You can send in your injectors to Mepeh injectors or buy a rebuild kit from them.
    You can place an order here
    Lots of good reviews here
    I got a set of s50/m50 green top 17lb injectors for free.
    Only thing wrong with them was one missing pintle cap.
    I contacted Dimitry owner of Mepeh injection, he was very polite I met him at his house to pick up a rebuild kit for my injectors. He offered to install my injectors on his machine to flow match them and test them out.
    We ran them at 3 bar at 7k rpm
    and up to 4 bar and 7k rpm they passed all the test.
    Also ran a draining cycle and they all where very close to one another.
    Cutting the pintle caps off
    Old injector filters vs new high flow filters.
    Injectors completely disassembled and cleaned.
    Rebuild kit plus a few spares not in the picture.
    6 high flow filters
    6 upper O rings
    6 spacers
    6 lower O rings
    6 pintle caps
    Filter extraction tool not in the picture
    Assembled just need to put some Vaseline on the o rings
    Installed with a new 3.0 bar fuel pressure regulator
    Installed
    Unplug negative battery terminal for 30
    Minutes and it will help the ecu clear out and help calibrate to the new injectors on the first test drive.
    I documented some of the injector rebuild process for those interested.
    3 short clips but it may help someone tackle this job.
    Step 1
    Step 2
    Step 3
    Project
    Parts for Sale
    Feedback
    YouTube Channel
  • Kershaw
    • 11822
    No pic of how to actually remove the filter?
    AWD > RWD
    • dnguyen1963
      • Nov 2011
      • 2651
      You can use a screw to pull them out.
      • jeffnhiscars
        • Jun 2011
        • 6011
        There's a pic of the filter removal tool i "engineered" in my Cabrio build thread. Very hi tech as you will see
        Alice the Time Capsule
        • iwantspeed
          • 3164
          Kershaw watch the videos it shows it there
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • TrentW
            • 2815
            I have 6 Bosch green top injectors that you can have free, just pay me $10 to ship.
            PM me if int.
