My range dosent show up right. ill have like almost an empty tank and it will show up 147 miles left. i swaped out clusters... could that be why?
there is a hidden cap on the left bottom corner of the OBC. use a screw to pop it off and inside there should be a philips type adjusting screw. i forgot which direction you spin it, but you can adjust the fuel reading on the OBC with this.
I've always wanted to take advantage of the security provided with that, but If i do the M50 swap would this still be useable? if restore to functioning status?
I read in an article the other day that speedometers are supposed to be set higher than the actual mph for some type of safety requirement. I believe this is something all car manufacturers have to do for all production cars.
If you hit the temp button at a low enough temperature so that the ºF or ºC flashes (the "ice warning"), and while it's still flashing you press the 1000 and 1, the fuel remaining comes up (like always), but this time the "L" flashes like the ºF/ºC was.
i'm thankfull i dont have a "low enough temperature" around here...Neways THANKS for this thread lol i just got my OBC working today and i had a blast playing with it...miami haitians watch out for CODED James Bond edition e30 o.O
No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold] http://youtube.com/watch?v=pTj7Hn9v5Rs
I had my obc Working yesterday. wired a radio in and now radio and obc dont function.checked fuse,its ok. does radio and obc Share 12v Power supply? the radios constant power supply shows one volt, but the switched power still works with twelve volts
just messin with you!!!
bet you all didnt know that if it starts blinking and crap, if you punch the dash, usually it starts working again.
not ususally, dude, ALWAYS. it ALWAYS starts working again.
The OBC in my euro car changes minutes every like 30 or so seconds. its completely fucked. the backlight burns out about three days after i replace it too, so i just stopped caring.
1989 Bronzit 325ia- Sold
1988 Delphin 327i- Sold
1995 Cosmos M3- Current
