the four way switch on the 13 button obc or the 6 button obc?
im confused as you what you are asking.... are you asking what the switch does on the big obc?
yeap, what does it do ?
on the 13 button OBC, as seen here and it reads...
Also, how do you adjust the speed reading on the OBC? My speedo is pretty good (I was in convoy with 3 other cars - a stock e36, a modified e46 and a stock e30 plus my modded e30 all with CB radios) and all our speedos were the same. My OBC reading was about 10km/h slow.
I don't think that you can change the speed reading. Most BMW speedos tend to be about 5 mph off, which is roughly 10 kmh.
BTW where can I get the code plug to update my 6-button OBC to the 13 button? All I know is that I need the green plug from a car originally equpped with the 13-button. My car also had the exterior temp sensor ripped out by a wayward pothole. Does this plug into the back of the OBC as well?
As far as my speed query goes, we belive that the speedos are pretty good and the OBC is out. Funny that considering it gets the signal from the back of the IC.
not ususally, dude, ALWAYS. it ALWAYS starts working again.
The OBC in my euro car changes minutes every like 30 or so seconds. its completely fucked. the backlight burns out about three days after i replace it too, so i just stopped caring.
Haha, mine does that, I just punch it and it goes right back to not working properly.
its easy. Set the display to time. Use an ink pen or similar prodding tool to push the tiny recessed button and then the number buttons at the bottom to change the digits.
