DIY - Odometer Rebuild
  • GOT8SPD
    • 270
    #106
    A few months back, I replaced the gears in my odometer from Garagistic and it was working fine. The problem I have now is that all of a sudden it stopped working. I took my cluster out, and all the gears are in perfect order still, I put it back in the car, it worked for .2 miles, then stopped working.
    What else could it be?
    I have multiple issues with my cluster because the fuel gauge always reads FULL and now my odometer stops working…I have no idea how much gas is in the car so I have to mentally keep track of how much I'm driving…ugh…
    • jeffnhiscars
      • Jun 2011
      • 6011
      #107
      Im having the same issue with my motometer speedo. I went 15k without issue after installing the garagistic gears then when resetting my trip meter my finger slipped and the odo stopped. I figured I jammed a gear so pulled the cluster. The gears looked good, screws werent too tight etc. Put it together and it worked fine for a week or so. Now it just works for a while then stops then starts again when it feels like it. Im quite certain its a bad solder joint since the SI batteries are new.
      A pic of a bad odo solder joint would be nice
      Alice the Time Capsule
