im desperate to know the location of these rocker drains op mentions.. any pics of the little perforations in the sheet metal? I'm having a strange leak only in the rear right footwell area. i did some tests and found out that it was leaking from the windsail grommets holes into the wheel arch and into the rear footwell area if car was parked looking down, here are the pics
![](http://i285.photobucket.com/albums/ll56/schtozo/e0b35e74.jpg)
See the water drop in the rear hole
![](http://i285.photobucket.com/albums/ll56/schtozo/ead12e8c.jpg)
i did take the trim piece out and so the grommets, they were destroyed, i filled the holes with black rtv and inserted rubber bumps from an auto part plus taped over them to discard the leak they were causing. the leak stopped from there with the hose test. but for my surprise the next couple of days the carpet was soaked again!!
I'm now thinking it might be the rocker drains, i did plastidip my rockers a month ago moreorless, and the problem started about the same time i figured later after reading this [post, and thought the plastidip may have covered the perforations...
any help is greatly appreciated guys, pics would be awesome
