Replacing the E30 Heater Core and Valve
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
I began looking into my heating issues lately. Is there fuse that may need changing for the heater control valve to receive power to open (fuse 20 I think)? Mine seems to be in the closed position (when plugged in or not. I have removed the valve and hooked it up to see if I can blow air through w/ no luck).
Just trying to diagnose before spending more on a new valve (shows no wear or leaking). I have bought a new core since I'm in there, but haven't read about many valves being stuck in the closed position w/ or w/o power.
Thanks for advice.
Also, which line does that inline thermostat go into? The line coming from the head or the block.Last edited by d_elson0; 01-21-2015, 10:45 AM.Comment
i just installed the new version of the heater valve yesterday along with a new heater core and since its bigger you need to move a relay next to it. It way bigger than the original.
Just did this. Replaced everything with new - heater core, valve, and pipes. Yes the new version of the heater core is bigger, but loosen the nut on top and it swivels. A loose flyer in the bottom of the box said to finger tighten the nut on top of valve when in its final position. That's to work around the relay, etc.
The other thing I found is its much better to put the o-rings in place over the male part of the pipe, instead of fitting into the core side first. I pinched one o-ring when I first put it together and had a leak. The second time around I put the o-rings on the pipe side and put it together without any leaks. I didn't see anyone suggest this after reading through all the posts.
OP, thanks for a great write-up. Really helped me get this done rather easily. And I am truly thankful that I have an A/C car, because it looks like a bitch job if you don't!sigpic
92 325iC Diamantschwarz factory M-Technic appearance
99 M Roadster Dakar Yellow II
97 318ti Active Bostongrun DD
01 Z3 3.0i Coupe Black Sapphire
93 325iC Schwarz II. Sold, but not forgotten.Comment
RHD E30 Owners take note:
If you've got a Right Hand Drive E30 you'll need to remove the bracket that the brake booster runs through. Part #1 in this image.
The reason for this is that the E clamp and a number of the 8mm bolts are inaccessible until this bracket has been removed.
You should be able to safely remove this part without having to worry about the booster falling from the firewall.Comment
Lamont and Rollo would approve of that rig!1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
my valve is frozen closed also. and, oddly, we have had weather in the low 30s here in south texas. normally, you don't even need a heater core and most people bypass them, which is what I though had been done to this little 87 325, but its the valve.
I might make a quick ball valve set up for now. I have other things that require fixing to be safe instead of more comfortableComment
I just replaced my core this weekend, didn't fix my heat issue, valve works, I've bled the system numerous times and haven't really got that hot air. Only way to get things to warm up is using the recirc. Before I replaced it I pressure tested the system and there was a pin hole leak in from the heater core. When I was pulling off all the hoses there was no coolant in the heater aluminum pipes and I am wonder if something is blocking. The heater core, return and feed are both hot so I assume coolant is reaching it. Enough ranting, maybe someone has a ideaBuild Thread
https://www.r3vlimited.com/board/sho...d.php?t=419655
Parts Thread
https://www.r3vlimited.com/board/sho...d.php?t=408302Comment
Fill your cooling system through the upper radiator hose. See if that helps your issue.I just replaced my core this weekend, didn't fix my heat issue, valve works, I've bled the system numerous times and haven't really got that hot air. Only way to get things to warm up is using the recirc. Before I replaced it I pressure tested the system and there was a pin hole leak in from the heater core. When I was pulling off all the hoses there was no coolant in the heater aluminum pipes and I am wonder if something is blocking. The heater core, return and feed are both hot so I assume coolant is reaching it. Enough ranting, maybe someone has a idea
all parts ordered. i am going to give it a go in the next week. hope i have a running working heater soon.Comment
