Replacing the E30 Heater Core and Valve
  • mbonanni
    • Sep 2011
    • 6236
    #196
    My ball valve style fix is still going strong, was less than $10 to do. Just have to manually open/close if you want to use AC. However my car currently doesn’t have working ac soooo
    • ak-
      • 12422
      #197
      Day 2, 100*F weather, no leaks.
      1991 325iS turbo
      • bbkhine
        • Jul 2018
        • 2
        #198
        which hose to connect to heater valve
        Appreciated if you can advise me on which hoses that the heater valve (PART#: 64 11 1 386 707) be connected to, either to the hose coming from the back of the head or the hose coming in from coolant reservoir. Both heater valve and heater core hoses are all metal in my 1990 BMW 325i. Those hoses were bypassed by previous owner and I just replaced them with a new heater valve and heater core. Thank you in advance. Sorry..I am new the forum.
        • Melon
          • Mar 2018
          • 1311
          #199
          Back of the head to the bottom aluminium line.
          Top aluminium line goes to the radiator.
          I do things.
          • bbkhine
            • Jul 2018
            • 2
            #200
            Thank you! I will revert those back as I have connected wrong. No wonder I have no heat. I will keep you posted.
            • shoshottz
              • Jun 2016
              • 128
              #201
              any chance you can do a write up on that open close valve thingamabober!?
              Sent from my iPhone using Tapatalk Pro
              • jjc034
                • May 2018
                • 107
                #202
                Take off the kick panel and behind the plastic ducting you will see the heater core Tubing and valve. You will need to loosen the engine bay hose clamps first, then unscrew any of the mounts on the inside that hold the piping in place, remove the heater core cover, unclip heater valve connector, then wiggle out. Be careful though because it will be messy
                Sent from my SM-G930V using Tapatalk
                • shoshottz
                  • Jun 2016
                  • 128
                  #203
                  sorry @jjoc i meant a write up on this! seriously!
                  • eternal24k
                    • Jul 2017
                    • 507
                    #204
                    so if i have no AC (24v swap), can i just fab up a straight pipe and forget the entire heater valve? any reason why i wouldnt want to?
                    • mbonanni
                      • Sep 2011
                      • 6236
                      #205
                      I wish I had more pics, but that’s all I’ve got. The valve is $10 from home depot. Just takes some clamps and some coolant hose to fab up.
                      Also, I think making it a straight shot will cause your air to blow max heat all the time. Since AC wont matter in your case I guess it depends if you want to control the heat or have a fan.
                      • eternal24k
                        • Jul 2017
                        • 507
                        #206
                        Hmmmmm, this helps me reconsider
                        • shoshottz
                          • Jun 2016
                          • 128
                          #207
                          @mbonanni
                          last questions...
                          i dont have ac but sometimes i enjoy the the blower motor lol...
                          if i close the valve, essentially im closing coolant flow off to the heater system which in turn would then allow the coolant to just cycle in the engine as if the heater core was bypassed right?
                          • mbonanni
                            • Sep 2011
                            • 6236
                            #208
                            Yes that is correct, or at least that was my understanding of how the system works. I could be wrong though.
                            • jjc034
                              • May 2018
                              • 107
                              #209
                              @mbonanni
                              last questions...
                              You are correct - closed disables hot coolant from going through the heater core, causing there to be no heat.
                              • tenkaichibudokai
                                • Jun 2019
                                • 2
                                #210
                                Can anybody tell me how to remove this black plastic vent? I can only see one screw on the bottom right which I took off but I can't see anywhere else it's attached to.
                                Enviado desde mi Nexus 6P mediante Tapatalk
