DIY - ABS relay repair - Fix that ABS light
  • Panici
    • Dec 2009
    • 2535
    #91
    Link in first post is broken, but I managed to grab a copy, with the original pictures.
    See the PDF attached to this post.
    • EddieV2
      • May 2016
      • 3
      #92
      Thank you! Mine's been on forever
      • driftxsequence
        • Apr 2015
        • 203
        #93
        Repaired the relay under the dash last night...unfortunately the light is still on. You can hear the relays at the pump clicking at key on now. Anyone experience this?
        325IX Build Thread
        RX7 Build Thread
        • cscracker
          • Jan 2017
          • 131
          #94
          If, like me, you're awful with a soldering iron, you can do what I did and just solder the tab right to the base (instead of trying to add wires or replace the fusible link), and put a fuse inline. Cut the wire that connects to that tab, crimp spade connectors on the ends, and plug in a 7.5 amp fuse. I got a little fancy with mine and used some heat shrink to hold the spade connectors together. Cheap, easy, doesn't require skill with a soldering iron.
          • Alpinweiss II
            • Mar 2017
            • 23
            #95
            Very helpful, thanks!
            • cobraken
              • Oct 2004
              • 674
              #96
              subscribed
              Randall Racing and Engineering
              Acworth, Georgia, 30101
              http://www.facebook.com/RandallRacingandEngineering
