E36 to E30: What can be swapped?
  • HellzMindPlaya
    • 395
    #46
    When you swap using e36 stuff it is generally accepted that you should use e36 M3 stuff, and then that it needs to be 96+... regular 325i struts and knuckles will give you a tire that is no where close to center in the front wheel well, that and the spring diameter of e36 325i struts is very big compared to e36 M3 springs and e30 springs (which are the same size)(use e30 springs)...
    For more info check out the 5 lug swap in the suspension section... This topic is the best in my opinion
    e30 Sold long ago - Too many BMWs since then... For now 2006 M5
    • borrihong
      • 134
      #47
      i believe you can only convert the Z3 or the 3-Ti e-36's for the rear five lug
      "evil always prevails....because good is dumb"
      • Gadea
        • 454
        #48
        mmhhhh....what about sway bars?
        1998 528i auto on staggered DSII
        • DeMelloe59
          • 1
          #49
          Hey guy's is there a link that we can go to on this complete swap???
          I'm thinking about doing the E36 to E30 swap.
          HELP>>>>>>>>
          • iwantspeed
            • 3164
            #50
            center console can be swapped
            ebrake handle
            shift knob
            shift lever
            e36 m3 seats(vaders)
            temp sensor(solder it in)
            ///m oil cap
            sunroof switch
            steering rack with tierods
            motor
            trans
            driveshaft(328 with some mods)
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • 3Twenty5
              • Aug 2009
              • 113
              #51
              HELP>>>>>>>>
              ^huh?
              • beatnic
                • 2
                #52
                can a m20 e34 rear end be swapped into an e30 318i?
                • Rocla
                  • 922
                  #53
                  Yes, or atleast the 520 one, with e30 rear cover.
                  m20 520i has the shortest ratio of them all 4,45:1
                  Current:
                  BMW 320i 2d 2.0 m20 -88
                  BMW 325i Cabriolet 2.5 m50 -88
                  BMW 316i touring 1.6 m40 -90
                  BMW 320i 4d 2,2 m54 -01
                  • a.b
                    • Jan 2011
                    • 4
                    #54
                    what about sunroof cover?
                    • Matt-B
                      The Waffler
                      • 3856
                      #55
                      e36 325i driveshafts. If doing an m50 swap with a 240 transmission.
                      • nikole
                        • Jan 2011
                        • 1
                        #56
                        Originally posted by M///BMW
                        Almost everything can be swapped...just something might require more work then others...
                        Sorry I have nothing to offer, I clicked hoping to find something useful in this thread. It needs to be organized as its a question I've been wondering about for a while. And I think I am not alone!
                        Ps3 downloads
                        Ps3 download
                          • 34847
                          #57
                          E36 wiper relay
                          E36 gauge cluster needles
                          tachometer/econometer motors
                          I found out the last one by accident..
                          • NbAmTwE
                            • Jul 2010
                            • 148
                            #58
                            Nando, are you saying you can swap the e36 rev gauge or just the motor that operates it?
                            UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
                            stripped out e30 rally project - in progress
                            M50NV -> M50TU E34 swap underway
                              • 34847
                              #59
                              Just the motors
                              • McGyver
                                • 4636
                                #60
                                Originally posted by HellzMindPlaya
                                ...the spring diameter of e36 325i struts is very big compared to e36 M3 springs and e30 springs (which are the same size)(use e30 springs)...
                                so you're saying that e30 H&R Sports will work on e36 318ti rear and e36m3 fronts? (the stuff i've traded for has e36 BavAuto sports, but i think i would rather use the H&Rs)
