Sway Bar Sizes
  • Spaz
    Crazy Canuck
    • 2276
    Sway Bar Sizes
    Stock:
    318i(m10): Front: 18mm Rear: none
    318is(m42): Front: 20mm Rear: 12mm
    318ic(m42): Front: 21mm Rear: 12mm
    325e(pre 9/86): Front: 18.5mm Rear: 12mm
    325e(9/86): Front: 20mm Rear: 12mm
    325i(m20): Front: 20mm Rear: 12mm
    325is(m20): Front: 20mm Rear: 12mm
    325ic(m20): Front: 21mm Rear: 12mm
    325ix(M20): Front: 17mm Rear: 14.5mm
    325ix Touring(M20): Front: 18mm Rear: 14.5mm
    M3(s14): Front: 19mm Rear: 14.5mm
    Aftermarket:
    AC Schnitzer: Front: 20mm Rear: 16mm
    Eibach: Front: 20mm Rear: 16mm
    Suspension Techniques: Front: 22mm Rear: 19mm
    Ireland Engineering (adjustable): Front: 25mm Rear: 22mm
    H&R (adjustable): Front: 22mm Rear: 18mm
    Racing Dynamics Early Style (adjustable): Front: 22mm Rear: 16mm
    Racing Dynamics Late Style (adjustable): Front: 22mm Rear: 19mm
    M-Technik: Front: 20mm Rear: 14.5mm
    If you have more info to add, post here and i will update the faq.
    Enjoy.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
  • randomtask37
    • 3154
    THANK YOU!
    ive always wanted a list like that.
    :cheers:
    98 M3/4/5
    • trent
      Re: Sway Bar Sizes
      Originally posted by Spaz
      Racing Dynamics (adjustable): Front: 22mm Rear: 19mm
      Correction:
      What you have listed is currently how the RD bars come (22mm/19mm). A few years ago Racing Dynamics actually offered two different bar sets for the E30. The 22/19 set was for the E30 M3. They offered a non-M E30 specific set with a 22mm front bar and a 16mm rear bar. I am lucky to have one of these sets and I don't there are many around.
      HTH,
      • Spaz
        Crazy Canuck
        • 2276
        Re: Sway Bar Sizes
        Correction:
        HTH,
        there u go my man.
        Cam .W '91 325is
        • M-technik-3
          • 18946
          M-technik anti rool bars F 20mm R 14.5mm
            • 34827
            thought I'd add, 325ix touring front bar is 18mm, rear is still 14.5 however.
            • Matto
              • Jan 2004
              • 800
              What size sways came on the alpina cars?
              • Spaz
                Crazy Canuck
                • 2276
                updated :)
                Cam .W '91 325is
                • ACS325ic
                  • May 2004
                  • 122
                  Re: Sway Bar Sizes
                  Stock:
                  Enjoy.
                  I think if you research you'll find that the 87 325/e/es (9/86-9/87) has an oddball one year only rear bar size of 13.5mm.
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    Is it worth the upgrade in my car from the 18mm in front to the 20mm?
                    Originally posted by Gruelius
                    • ZiMMie
                      • Jun 2004
                      • 968
                      anyone with an early 84 318 try upgrading rear sways? is it a bolt on?
                      www.stancefactory.com
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        Yes, I added the sways from a 325is to my 84 318. The rear bar is definitely bolt on. There are tabs on the trailing arms and chassis for the bar. You just need the bar, links, and hardware. It's not that bad of a job. Put the links on the bar before you bolt the bar in under the car. Then you'll need to put the rear of the car on jackstands, remove one wheel and spring on the same side. Then slide the bar straight in over the diff, orient it correctly and bolt it in to the chassis. Then put the spring back in and wheel back on and then lower the car a bit. Then bolt the links onto the trailing arm tabs and lower the car all the way down. Adding the rear bar to the 318 made a HUGE difference in handling.
                        • ZiMMie
                          • Jun 2004
                          • 968
                          i got 90 325i Disc brake Rear conversion so i am guessin it should bolt right up. i was jst wonderin if there was predrill holes for the mounting hardware in the chasis. or i have to drill new ones?
                          thanx for the info.
                          • Chris325/325i
                            • 40
                            Re: Sway Bar Sizes
                            Yep, I found this out the hard way. Ordered new 12mm bushings for my 87 325, did not bother to check since they are all 12mm (ex the ix and M3). Go to put them in and could not figure out what was wrong until I saw the 13.5 marked on the old bushings.
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              thanx for the info.
                              Holes are already in the chassis.
