Sway Bar Sizes
  • DanGillan
    • Mar 2004
    • 4061
    what did a 1991 318i four door with an m42 have for sway bar sizes? thanks,
    Dan
    Dan
    • DanGillan
      • Mar 2004
      • 4061
      anyone?
      Dan
      • DanGillan
        • Mar 2004
        • 4061
        bumpzilla
        Dan
        • Thomas Olivaux
          • 42
          Thx for the list !
          Alpina B6 3.5 as 18.5mm front and 14mm rear ;)
          See you
          Thomas
          - E23 735i '83 (for sale)
          - E23 745i Executive '84
          - E30 B6 3.5 '86
          - E34 M5 3.6 '90
          - E30 325i cabriolet '92
          - E46 320td compact '02 (for sale)
          • doucy2
            • Sep 2006
            • 1311
            Dan
            also would like to know this?
            • Rocla
              • 922
              Dan
              Ís this a trick question?
              BMW never made such car.
              1991 318i had m40 engine, 18,5mm in front(20mm with sport suspension) no rear sway.
              M42 engined cars were named 318is, and were only available as 2d version. 20mm front and 14,5mm rear.
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • doucy2
                • Sep 2006
                • 1311
                hmm i definatly own a US m42 318i 4dr, so its not a trick question.
                • Rocla
                  • 922
                  Ok weird enough. I ETK confirms, U.S. 318i realy had that engine, my bad.
                  EDIT: 20mm on front and 12mm back(14,5mm with sport suspension).
                  Current:
                  • backtrail69
                    • Jul 2005
                    • 4471
                    IE also offers the 22/19 setup along with 25/22. I will soon to have both sets to compare them.
                    :: PNW Crew ::
                    '87 325 4dr, '74 2002
                    • delphini
                      • Apr 2006
                      • 680
                      On my 87 325i cabrio the rear end link often "pops" off, and i've put the end back in several times but its still coming off.
                      Anybody know why this is happening and what can be done to correct this problem?? Any ideas would be helpful, thanks .
                      :pimp:
                        • 34847
                        it pops off because the bushing is worn out. you need to replace it.
                        • E30RedtopSR
                          • 202
                          my Koni sway bars are 22 front 16 rear, for what its worth
                          • SchnellerVert
                            • Sep 2005
                            • 3948
                            Koni makes antisway bars? I know they used to sell matched rate spring packages but never heard they did asb's.
                            • E30RedtopSR
                              • 202
                              Bought mine from here like 15 months ago, also got the springs(last set)
                              Super N.O.S, crazy cheap price . Came with full adjustable heim joint links. Front bar has three hole rear has two.
                              • SchnellerVert
                                • Sep 2005
                                • 3948
                                Ah
                                Koni Sway Bar Set by Suspension Techniques.
                                Great price.
