DIY - Walbro 255 fuel pump retrofit.
  • Dj Buttchug
    • Jun 2010
    • 7677
    i need to do this on my car. nice pics!
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • DÌEGØ
      • 690
      so does anyone know if this will work on an early E30 with an external pump?
      ultimately I wanna run the 255 and just dump the external, has anyone done this?
      Driving:1990 325iS, 2007 335i :devil:
      past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
      • gemztoy86
        • Sep 2009
        • 106
        Would also like to know this as well...
        1986 325e
        My other ride...The Titan of trucks!
        • DÌEGØ
          • 690
          i searched around and found a couple people that have upgraded their in-tank pump to a tre or walbro and kept their external with no problems....furthermore I believe taking out the external should have no ill effect either. I'm still planning on replacing my in-tank with a walbro 255 but i havent decided if I'll leave it or go single pump....hope that helps ^^^
          edit: the early style E30s with external pumps have a weird pick-up assembly and require a bit more work to make either of the above-mentioned pumps work. you will need to brake the weld on the return line to the pick up line and straighten the former...
          • nasty50
            • 36
            wow thanks for this dyi iam going to save hella money(fuel pump went bad recently).called around for fuel pump for my e30 and got qoutes from $220 to $350.i also owned lots of mustangs and have stock fuel pumps and walbro 255.needless to say iam going to be on this asap.thanks again.
            • homegrone30
              • Jun 2007
              • 1449
              I just did that exact thing this weekend and it seems to be fine. The only thing that I could see as a problem is the wahlboro crapping out premature from trying to push through the other pump. But thats just my
              • homegrone30
                • Jun 2007
                • 1449
                I didnt do it this way I hooked it up normally, then made a few bends in both lines and cut a section off the feed line for some clearance. The only modification that I made to the pump was I pulled the factory wiring connector off the pump assembly and ran new wires through the hole and filled the little hole with gas tank putty.
                • DÌEGØ
                  • 690
                  good to know, thanks!
                  • mkcman17
                    • Jul 2010
                    • 8240
                    what's the point of this? does it allow for more pressure or is it just a cheap alternative?
                    1989 LN106 Hilux / 3.0TD SFA
                    1974 2002tii / stock
                    2002 IS300 / 5spd LSD
                    • Danny
                      • 14216
                      Cheap alternative.
                      Also I used zipties.
                      • lateracer
                        • Sep 2009
                        • 302
                        I have an early dual pump setup and the in-tank died. I installed the TRE pump in place of the old one, but haven't tested it yet (still got motor work up front to address).
                        Can you explain this fix a little more? Not sure what you mean with feed line...mine is still in place. What did you bend and what did you cut off?
                        • bejbis
                          • Dec 2008
                          • 596
                          Seriously, stay away from the TRE pumps. i've run a couple of them that both failed on different cars in short order. TRE's customer service was horrible and they didn't honor their warranty. Ive run quite a few more walbro's without fail for years, they are more than worth the extra 20$ or so.
                          -Dan
                          -Dan
                          • kodylk08
                            • Feb 2011
                            • 4
                            thanks for the write up... just got done doing it.. went pretty smooth. good pictures too.
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              bought some cheap 255 lmph fuel pump that interchanges to ther walbro. was $55 shipped will install and take pics.
                              Originally posted by 325Projectz
                              don't listen to the diagram... listen to mr. swiss.
                              :nice:
                              • Mr.SWISS
                                • Nov 2005
                                • 1251
                                Did my install and YaY! The 89 325is that sat dead for 10+ years is alive!!
                                Here is what I used that came with the kit. $55 shipped, not a Wal but performs the same.
                                Here's the pics, notice the suction hole on the high flow compared to stock.
                                (Sry phone pics)
                                Notice the opening in the bracket needs to be trimmed away to accept the larger opening.
                                finished setup, I chose to unsolder the old wires and solder my new ones in, you may want to splice the existing wires.
                                :nice:
