MSPNP: Fuel Table Cells Peak at 255
  • ovo_e30
    • Aug 2020
    • 36
    I've been trying to tune my M20 Turbo, however, Tuner Studio doesn't allow me to add more fuel into my fuel map.
    Whenever I go into boost my AFR's go into 13-14 which isn't a good thing.
    Ignition: WastedSpark/Bosch Multicoil Pack Module
    Fuel: High Flow in-tank Fuel Pump + 42lb injectors.
    FPR: stock
    There's no way I should be getting lean AFR readings at 1-5psi. I have the stock FPR with the reference vacuum line running directly to the manifold with NO tee's on it. I'm thinking maybe I have a setting improperly set.
    Any thoughts?
  • Andre3127
    • Dec 2017
    • 291
    Is your FPR working? Pull the vacuum line off the FPR and smell for fuel. Try to rig up a fuel pressure gauge. Just because you have a good pump doesn't mean that a line couldn't be clogged. Doesn't hurt to verify.
    Budget E30 Parts - Used and Reconditioned parts for your BMW
    • Jaxx_
      • Dec 2009
      • 1880
      What are your deadtime settings? Do you incorporate AFR target? What is your AFR table? Are you multiplying MAP?
      You should really post the whole tune and ideally a data log to really diagnose this.
      • varg
        Florida Turbo Man
        • May 2014
        • 3418
        If you don't have low fuel pressure, you've made some mistake(s) in your basic settings if this is happening; MAT air density, general settings, injector dead-time, all should be double checked.
        IG @turbovarg
        '91 318is, M20 turbo
        • ovo_e30
          • Aug 2020
          • 36
          Got my hands on a Fuel Pressure Test Kit and low n’ behold, I have low fuel pressure at the fuel rail as well as between the filter and fuel pump. I pinched off the vacuum reference line going to the FPR and got no change in pressure. I forgot to pinch off the return line in the midst of my troubleshooting but I have a hunch it’s the FPR.
          Edit: ok so I did a quick check on the fuel pump to see if anything was astray and noticed that the hose that comes off the pump and goes into the hanger broke. Apparently the strap I wrap around the pump/hanger wasn’t holding on tightly enough so the pump was dangling from the hose and wearing it out causing my issue. FIXED the hose and now I have normal fuel pressure. The fuel table needs to be re-tuned but that’s okay.
          • ADEN
            • 620
            Keeping the vacuum hose attached to FPR made tuning off idle WOT harder for noop like me lol.
