E30 - M20 - ICV Factory Frequency Setting
  • E30Bastard
    Shimmy Shimmy Ya
    • Nov 2018
    • 245
    I have spent far too much time searching the forums for this simple answer.
    This is what MS2 says:
    "Frequency to operate at. This varies with valve type. Ford/Bosch valves typically operate 50-100Hz. Miata valves are closer to 300Hz.
    Be aware that above 78Hz the output becomes less precise."
    Does anyone have a definitive answer on what the factory M20 ICV hz setting in MS should be?​
    "It wouldn't be there if it wasn't..." - Milton Berle
    1988 325iS - M20
  • Kershaw
    • 11822
    Can you download the starter tune and check? I don't think I have ever adjusted that, whatever setting the starter tune has works well.
    AWD > RWD
    • digger
      • Nov 2005
      • 6199
      120hz is what i use based on what people measured/tested on the old e30tech forums
