what ignition box works with stock ecu?
  • xalier
    • 46
    I have contacted a couple dealers of ignition boxes and i cant seem to find one that will work with my car 89 325i. I have searched a few forums and searched google without any luck. I figured some of you guys probaly went through this before you got a MS. So I need to know what boxes have you had success with or will work on e30 and also which wiring schematic did you use to install? any info is greatly appreciated.
  • Jaxx_
    • Dec 2009
    • 1880
    i would also research megajolt too, if you're going down this route.
    • xalier
      • 46
      thats a new one to me.. is this what e30 users use the most?
      • LowR3V'in
        • 4209
        http://www.autosportlabs.com/megajolte-p-41.html
        megajolt is a standalone ems for spark only.
        Just for the carburetor guys and I don't think it has cdi either.
        • DaveSmed
          • Apr 2007
          • 1407
          You looking for something like an MSD? Which one do you have your eye on, the 6A?
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • xalier
            • 46
            well the story is i bought a mallory hyfire 6, and couldnt get it to work right. made the car run like crap. i called mallory and they said they didnt offer any support for bmws and didnt recommend using it so i took it off and bought a jacobs mastermind. now after reading the instructions for the jacob it can't be used without a aftermarket box. so i figured i would make a thread and see what people have used and it worked before i buy another box lol..
            • xalier
              • 46
              no ideas?
              • LowR3V'in
                • 4209
                Good old msd 6al is an idea.
                this person explains how to wire it.
                • DaveSmed
                  • Apr 2007
                  • 1407
                  How did you have the Mallory hooked up?
                  Red and black heavy wires are obvious.
                  Orange and small black wires are replacing the green and black wires at the coil
                  Green that used to go to the coil goes to the small red wire
                  Black that used to go to the coil goes to the white wire
                  Should have worked fine hooked up like that.
                  -Dave
                  • reelizmpro
                    • 9558
                    Jacobs, MSD are two that come to mind.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
