Anyone running megasquirt 3 yet?
  • semaj4712
    • Mar 2012
    • 3069
    I am thinking about running the brand new MS3-Pro with high pressure fuel pump and 24ib injectors on my M50 and wanted to know if anybody had any experience with the MS3-Pro on this or any other engine and could throw in their thoughts and experiences. Thanks
    MS3-PRO http://www.diyautotune.com/catalog/m...ade-p-514.html
    MS230-K kit http://www.diyautotune.com/catalog/m...ade-p-513.html
    29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
    72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
    Gewerkschaft der Polizei Sticker/Clings For Sale $8
  • GunMetalGrey
    • Dec 2010
    • 1499
    Correct me if I am wrong, but those are both MS II kits...
    Sent from the future. Or my phone, who knows.
    • semaj4712
      • Mar 2012
      • 3069
      oops you are correct, fixed, I found a few threads on this from a long time ago, but it seems like they never finished their tune, and another thing is the ones I have found are non-vanos
        • 34844
        I've been running it since 2010. hoveringguy is using it with double vanos on his M54. I know there are a few M5x's running it and an S54 too.
        I'd go with the newest MS3 kit from diyautotune that comes pre-built with automotive grade connectors. There's basically nothing to modify on an MS3 build, and the V3.0 board + MS3 + MS3x takes up a lot of space. The worst part is you don't need about 75% of the circuits on the V3.0 board when using MS3 with an MS3x, so it just takes up space.
        • semaj4712
          • Mar 2012
          • 3069
          This makes sense, yea I am pretty familiar with tuning just never before on megasquirt or setup of the engine management before, so I feel like I am doing it backwards slightly...How do you like it thus far?
          • semaj4712
            • Mar 2012
            • 3069
            Nevermind just read through your build thread...sounds like you really like it
            • hoveringuy
              • Dec 2005
              • 2735
              Here's my thread:
              www.m54megasquirt3.blogspot.com
              I got it running extremely well using MAP and recently converted it to run from a generic e36 MAF. Not that much of a noticeable difference between the two..
              • semaj4712
                • Mar 2012
                • 3069
                Cool man thanks for the info
                • Wiglaf
                  • Jan 2007
                  • 1513
                  I have an older megasquirt, am considering upgrading for the faster processor. I believe this will improve light-load and idle response, particularly with smoothing out AFR. Seems a little on the chunky side right now.
                  Originally posted by u3b3rg33k
                  If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
                  • RobE30
                    • 959
                    Where is a good place for a "noob" to read up about Megasquirt etc? I've read through some threads and there is too much bs strewn throughout to get a clear picture. I really want to do this but I want to know what I'm doing, why I'm doing it and what parts I need to accomplish said goal.
                    09 BMW 328xi touring 6spd
                    05 Subaru Outback XT 5spd
                    87 BMW 325is
                    a few bicycles
                      • 34844
                      Megasquirt EFI fuel injection and ignition control. Product information, support forums, documentation and downloads for Megasquirt and Microsquirt ECU. Official site for MS1/Extra, MS2/Extra and Megasquirt-3.
                      also, there are some great write-ups on www.diyautotune.com
                        • 34844
                        even if you have a really old MS, you can upgrade it to a MS3 CPU. The V2.0 board is kinda crummy, but it can work. If you have a V3.0 motherboard, then it's a no-brainer.
                        • RobE30
                          • 959
                          I have some experience soldering (made a distortion pedal from a kit), would it be better to build my own or buy one that's pnp?
                          87 BMW 325is
                          a few bicycles
                          • hoveringuy
                            • Dec 2005
                            • 2735
                            I have excellent soldering and assembly skills, but decided to purchase the assembled MS3 because I didn't want to commit the time to assemble it, and because if there was an issue getting my car to run I didn't want to double-guess if it was the car or something I did wrong in assembly.
                            At this point, I would opt to assemble my next one.
                              • 34844
                              if it were me, and I were doing it again, I'd get the MS3-Pro and call it a day.
                              if the MS3-Pro were out when I was building mine, I would have fit it inside a stock ECU case and used the stock harness connector. They sell just the PCB too which you can wire up any way you like, and it's like 1/3 the size of an MS3 CPU, MS3x, and V3.0 motherboard.
