Looking for some opinions.
  • Boostesi
    • May 2011
    • 220
    I want to do a basic/entry level turbo setup on my e30 with m50tub25, Im planning on running a small snail small FMIC and maybe 5-7psi. the car isnt daily driven and is only used going to be used for cruises/ drift days. my main question is with tuning, do i need to go full standalone (megasquirt or similar) to support 5-7 psi? would the car run safely on a rising rate fuel pressure regulator and bigger injectors alone? or should i just go with an aftermarket chip burning company. im just very intimidated by megasquirt, not with building the board, just the tuning aspect afterword, seems to be a very grey area in the internet world.
    sigpicFellow e30 enthusiast
    Dont waste your time hating, aint nobody got time fo dat
    1986 bronzit 325es- SOLD
    1987 delphin 325i- parts car
    1990 scwarz 325is- m50 drift slut
    CHECK OUT THE BUILD!
    http://www.r3vlimited.com/board/showthread.php?t=229234
  • DmcL
    • Apr 2009
    • 260
    moates ostrich 2.0, tunerpro RT and a wideband..
    Currently E30-less
    - EthosMotorsports.com
    • ak-
      • 12422
      There is SO much support for stock DME tuning that megasquirt would absolutely never cross my mind if I had a 24v motor. Go to the Forced Indiction section on Bimmerforums and have your mind blown.
      1991 325iS turbo
        • 34835
        really? I doubt many other tuning solutions have been discussed more than MS.
        • IronFreak
          • Dec 2012
          • 3702
          I'll say this.....it's not really grey, just vast hahaha. I'm playing with my first MS setup on my build. Thankfully I have some very good friends that have played in that realm for awhile. But I have been doing my part to learn and understand what exactly I need to know. MS isn't grey, on the contrary they give you RIDICULOUS amounts of information. I personally am having trouble taking it all in, the possibilities of MS systems are only limited to the hardware you want to buy, it's absolutely phenomenal what you can control with that system.
          Instagram @rebellionforge
          • Boostesi
            • May 2011
            • 220
            your right there is tons of information out there its only grey to me since ive never dealt with ms before
