Going MegaSquirt
  • Bmwb
    • Jan 2013
    • 196
    Going MegaSquirt
    im confused between the 2
    and this
    which one would be the better choice for a stroked e30 , soon to be turboed but the thing is one comes with mapdaddy but needs a separate wiring harness and the other without mapdaddy but just get plugged into the regular harness , I am taking peoples opinions on this iv looked around and some people use the ms2 kit > some use the bosh one
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
  • jntar
    • 459
    If you dont want to wire up a new harness you can always buy the PNP Bosch kit and add the map daddy upgrade. If you don't plan on running very high boost, you don't really need the map daddy upgrade anyways.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • Bmwb
      • Jan 2013
      • 196
      so the mapdaddy can be added to the bosch kit alright then so the bosch kit would be the better alternative I rather not wire crap so im thinking of just getting the bosch kit atm im gonna run it as a stroked engine the turbo will come later on just ordered the bosch pnp
      20psi
        • 34847
        the stock MAP sensor is 2 bar so if you aren't going over 15psi you don't really need an upgraded MAP sensor.
        if you want the bee's knee's in PnP kits, talk to Whodwho. The nice thing about his kits is you have an upgrade path, but with the DIY 55 pin kit you are stuck with the microsquirt daughter card.
        • Bmwb
          • Jan 2013
          • 196
          I sat there reading about it last night idk right now I just ordered the DIY 55 pin kit since I don't have to deal with wiring , but I was going to talk to whodwho I should of but forgot all about him , will the whodwho kit and whodwho kit basically do the same though or? what's the difference that his isn't using the micro squirt daughter board
          20psi
            • 34847
            they're both PnP. Whodwho's is completely assembled and uses an MS2 CPU (which could be upgraded to MS3). I don't know if he has MS3 PnP kits or not.
            microsquirt is based off MS2 but it's all self contained so you can't upgrade or really modify it.
            the DIY 55pin kit will need soldered and assembled.
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              +1 for whodwho. Have one of his ms2 units for my iX, just waiting on some cooling bits / tbelt before install.
              Originally posted by priapism
              Originally posted by shameson
              • Bmwb
                • Jan 2013
                • 196
                had a chat with whodwho great guy and very helpful he explained to me the differences well either way I think im going to stick to the ms2 system anyways for now and get use to knowing how to use megasquirt and all , thanks for the help guys appreciate it ,although the soldering is what needs to be done im fine with that if I cant do it ill make sure someone dose it for me so I don't screw it up , and plus im also gonna go grab a laptop and put a fresh copy of xp < since basically a lot of tuners use xp and need it
                20psi
                • Bmwb
                  • Jan 2013
                  • 196
                  finally got this thing ready and is connected to tuner studio now here is what I found on the diy there are basemap tunes for the first start up and you can go from there what should I do? , use one of their base maps or set up all my own settings
                  20psi
                  • Bearmw
                    • 1323
                    I am also considering trying MS and have some questions. I have a NA B35 and I want to make a completely new engine harness rather than repairing a cracked beat up BMW one and would like to make a clean simplified design. Are the harnesses that DIY autotune sells recommended? I don't yet know all the features that are mandatory to basically make an engine run well vs. those added features that go into very advanced tuning. I am thinking it would be nice to have individual coils for all 6 cylinders and maybe eventually try to reference the cam position as well to run full sequential injection.
                    I don't mind doing the work but also like the idea of some components preassembled. What is most cost effective these days and what will give me the ability to fairly easily make additions and improvements when I am ready beyond just getting the engine running?
                      • 34847
                      it will definitely run better with full sequential injection. ditching the cap/rotor for a wasted spark or COP setup is more about reliability and maintenance than performance - it won't really run different. a COP setup can cost less than a set of stock plug wires, cap & rotor though.
                      You need a cam sensor for sequential fuel so making the jump to COP isn't that big anyway. Making a sensor setup is pretty simple too - a hall sensor from an E46 M54 (or similar), and a single "tooth" at the right position is all you really need.
                      building a harnesss from scratch can be tough but also very nice in the end. definitely getting a pigtail harness with crimped DB37 pins is a good idea. you can use parts of the stock harness, and you can get generic 2 and 3 pin AMP/tyco connectors for things like the ICV, injectors, etc.
                      • CLASH
                        • Nov 2013
                        • 39
                        How is your DIY kit going?
                        Is hard to tune?
                        What else you have to buy beside the kit?
                        Thanks
                        • Bmwb
                          • Jan 2013
                          • 196
                          bent my rod engines almost done being rebuilt and turboed , ecu ran great I had no issues until I messed up playing with a tune and injectors don't touch it if u cant tune im going to get it dynoed
                          20psi
                          • ZenitramNaes
                            • Jul 2012
                            • 150
                            Sorry to hear that, any progress since then?
                            '89 535i/5 Holset WH1E turbo
                            Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
                            • Bmwb
                              • Jan 2013
                              • 196
                              cabrio turbo build almost done fixing it and getting it ready to go
                              20psi
