Help with ms2 m30 base tune
  • Karlm30
    • Feb 2013
    • 13
    Hi guys almost done with my build I need to see if any of you guys would be nice enough to supply me with a nice base tune I can use to atleast drive to the tuning shop. If you have a finished tune that be even better I'm even willing to pay if its a finished product.
    Ms2
    7 psi
    44lbs injectors
    Stock m30b34
    Tia!! Any help will do
  • ZenitramNaes
    • Jul 2012
    • 150
    Hey Karlm30,
    Did you ever get a decent tune?
    '89 535i/5 Holset WH1E turbo
    Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
    • Paradox
      • Jul 2010
      • 337
      Found these base maps yesterday:
      This map will get you started, but you will still need to continue to refine it for your specific set up.
      • ZenitramNaes
        • Jul 2012
        • 150
        Greatly appreciated. I'll give those a look over, thank you!
        • whodwho
          • Jun 2008
          • 1547
          You can start with a M20 tune and adjust the required fuel and will get you going
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • ZenitramNaes
            • Jul 2012
            • 150
            Would you suggest that over the m30 base map for someone that has an m30 motor?
            • Jaxx_
              • Dec 2009
              • 1880
              check out mye28.com, there are quite a few ms guys there that will lend you a map for the m30.
                • 34844
                The differences will be pretty minimal.
                • ZenitramNaes
                  • Jul 2012
                  • 150
                  Got it, appreciate it guys.
