Wasted spark: Remove dizzy rotor mount?
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    When removing the distributor rotor for a wasted spark setup, should I remove the 3-armed mounting piece attached to the cam gear?
    Just worried about how the rotor mount without the rotor would affect the balance of the camshaft assy more than anything.
    Originally posted by priapism
    Originally posted by shameson
  • FLG
    • Sep 2011
    • 3165
    Do you have a delete plate? If not leave it on, you don't want some debris ot anything falling into the timing belt area.
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • Northern
      • 5284
      I could make up a delete plate, I guess it does hold that little plastic cover in place, but I don't see it being very useful.
      Just to confirm, I'm talking about the piece with the big stupid arrow pointing at it.
      • kamotors
        • Nov 2007
        • 7102
        I just left that and made a little delete cover
        7speedshop.com
        • Northern
          • 5284
          sounds good, if yours hasn't blown up yet, I feel fine leaving it.
            • 34844
            Get a cam bolt from an early 323i, then you dont need the rotor mount.
            • Northern
              • 5284
              Do you have a P/N? I assume you're using one with your COP setup, but realoem gives 2 P/Ns:
              11311266796 - M10X28
              11311714798 - M10x35
              Not sure why there are two so different in length. Stamped vs sintered cam gear?
                • 34844
                yeah pretty sure it's the shorter one.
                • Northern
                  • 5284
                  sounds good. I guess it will be pretty easy to tell once it is installed based on how many threads engage.
                  • Cyrix2k
                    • 593
                    I left it on without the rotor... you can remove it for cosmetics, but I don't think it will be a balance problem. Personally, I left the timing cover off too.
                    1997 540i/6 - stock
                    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
