wideband opinions
  • bmwm42
    • 6300
    wideband opinions
    Any opinions on either the lc1 or aem uego wideband im about to pull the trigger just would like some opinions from people who have used either or both ... thanks
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
  • yahh
    • Aug 2012
    • 800
    Used an lc1 for over 3 years without a problem. Just make sure you calibrate it correctly before putting it in and you'll be set.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
    s50 86 325e Project
    S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
    Feedback Thread
    • Jb325is
      • 2137
      I prefer the Innovate. The good thing about them is you can buy a replacement sensor from Autozone and they are easy to install. I work at a race shop and we use mostly Innovates, they aren't really trouble free in my experience, but they usually just need a new sensor or need to be re-calibrated. The AEM is self calibrating but I have found them to be a little tempermental. Stay away from PLX and AFX
      - '88 m54 coupe
      <3
      • george graves
        • 20003
        +1. I've taken apart my lm-1 (big brother to the lc-1) to see how they designed it, and I can say they make quality stuff.
        Originally posted by Matt-B
        • Good & Tight
          • Apr 2004
          • 2057
          The LM-2 is worth looking into also, it has data logging abilities among other features.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • jaywood
            • Jul 2010
            • 4528
            I had an LC-1 on my last e30 turbo build. It worked just like it should after calibrating it and what not. I would not use it again however after using the AEM UEGO on the new car I'm building. It is so much easier to install. No calibration needed either.
            They can both be had for about the same price on ebay.
            UEGO: http://www.ebay.com/itm/AEM-6-IN-1-D...debc11&vxp=mtr
            LC-1: http://www.ebay.com/itm/Innovate-LC1...56b341&vxp=mtr
            But like I said, I prefer the UEGO
              • 34839
              I've had an lc-1 for almost 7 years now, no problems.
              • bmwstudent
                • Sep 2011
                • 1364
                I recently installed the AEM wide band setup. Easy install, no calibration, very straightforward. Works very well.
                • ak-
                  • 12422
                  Lc-1 replacement sensor from Autozone or Orileys is also around $50 and offers a no questions asked 1 year replacement warranty.
                  Had mine for 2.5 years no problems already.
                  1991 325iS turbo
                  • whodwho
                    • Jun 2008
                    • 1547
                    That Bosch sensor works with the AEM as well but isn't the same connector so isn't exact replacement. Not sure if you can switch the connector shell out but I would think so.
                    The LC1 has been superseded with an LC2 but haven't looked into the difference yet.
                    My M20 Frankenbuild(s)
                    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                    • ZenitramNaes
                      • Jul 2012
                      • 150
                      I'm really happy with my Innovate MTX-L.
                      '89 535i/5 Holset WH1E turbo
                      Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
                      • squidmaster
                        • Aug 2011
                        • 2666
                        My lc1 works great and has consistently for over a year so far. Plus cheap replacement sensors!
                        • ZenitramNaes
                          • Jul 2012
                          • 150
                          Correct me if I'm wrong, but isn't the MTX-L (LM-2) the new standard for innovate, meaning it surpasses the LC-1?
                          • Jaxx_
                            • Dec 2009
                            • 1880
                            I've been running the DIY-SLC from 14point7.com and I like it. It's cheap too, and uses the bosch $50 wideband.
                            • george graves
                              • 20003
                              MTX-L is the wideband built into a round gauge.
                              As far as I can tell, they all use the same exact hardware inside. So what you are paying for is features. The new Lc-2 I believe is the same as the Lc-1 as far as I can tell, it's just repackaged.
