MS Vacuum tube routing
  • e3088ix
    • Oct 2013
    • 17
    Almost done with an MS DIYPNP install in my 88 if, but I'm curious where everyone is routing the vacuum line for the map sensor? All the tutorials/posts I've looked at just say, "route a 3mm line to the ecu from the FPR vacuum line" with no pictures of where the tube can fit through the firewall.
    Any help would be appreciated
  • Reichart12
    • Aug 2012
    • 2165
    Ive heard you can punch a new hole in the firewall plug where it has 2-3 raised bumps. My plug was already cut so I ran the vacuum line with the wires and wrapped the plug around it. Its not a tight fit to the firewall right now but I tell myself Im not done tidying up yet.
    Instagram: Reichart12
      • 34844
      This is how I routed mine
      I didn't run the tube through the grommet because I didn't want it to get pinched.
      There's a factory part with 2 vacuum nipples on it that I used to connect to the intake manifold. looks completely stock. I got it from an '89 325i, they came capped off.
      • EatsHondas
        • Sep 2012
        • 404
        Yes, same spot for me as well. I have my line right through the grommet with no shielding and my MAP signal is clean. No problems. I drilled and tapped the little 3-bolt cap on the intake manifold for a right angle fitting.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
