Megasquirt Timing and Fuel Map Thread
  • Jaxx_
    • Dec 2009
    • 1880
    #106
    Originally posted by Joegreen02
    Yeah I've been running the 284 on stock injectors for nearly a year running great. Almost regret going to MS actually. I thought I would get more out of it out of the box. I mean Turner motor sports makes a chip that drops in and performs great. Thinking I'll go back to that and leave it.
    Megasquirt is much more capable than a chip. Spend that money on a tuner that knows what they're doing and you'll enjoy megasquirt a lot more. Or learn to tune it yourself
    • Joegreen02
      • Dec 2018
      • 80
      #107
      Know a good one? I'm talking to a couple but I'm reluctant to pull the trigger gonna send a guy the maps I have developed that actually run decent and through a little coin to see what happens
      • justinpirie
        • Feb 2014
        • 111
        #108
        +1 on spending money on a tuner. You should use one that’s familiar with MS otherwise it could be a waste of money. There are remote tuners but you can’t tune advance without a dyno.
        MS is powerful but also a PITA.
        • Joegreen02
          • Dec 2018
          • 80
          #109
          Well I'm taking her to mission texas Friday to have it dyno tuned NA for the moment until I decide if I want to slap this SC on it or not. We will see how everything goes with the na tune first[emoji2369]
          • Jaxx_
            • Dec 2009
            • 1880
            #110
            PM me. I'm happy to get you up and running so you're not spending so much with a tuner. If you are are seeing 10:1 AFRs but it's running, you're half way there
            • Joegreen02
              • Dec 2018
              • 80
              #111
              Well I'm currently in Houston at a rig managers meeting. I'll be home Friday. It does run.and not bad but 10's are rich as fuhh and I'm sure I'll see good results on the dyno. The guys got great reviews
              • e30davie
                • Apr 2016
                • 1788
                #112
                If you set your AFR target table properly I found the auto tune in tuner studio to be awesome. Still requires fine tuning and you have to keep an eye on it, but you just turn it on and start driving around. Within about 30mins my brother and I had my car "tuned" to start, drive, idle quite good with reasonable AFRs across the board.
                The difficulty i think in DIY tuning comes when trying to sort out the air temp correction and acceleration enrichment. Lots of trial and error. Well and ignition timing, but thats a whole other story.
                • justinpirie
                  • Feb 2014
                  • 111
                  #113
                  This!
                  Buy the best version of Tuner Studio, too.
                  • Joegreen02
                    • Dec 2018
                    • 80
                    #114
                    The problem is I don't currently know what setting the afr table properly would look like. I have tried making several changes to the afr table and ve tables I have the car idling smooth and right where I want it. Blip the throttle and it will not hesitate to Rev to the 6300 limiter I have set for it. Pulls hard from a start to around 5k then starts a little missing cutting out and will not reach that limiter at all running through the gears. 5500 is as fast as it will turn then the cutting out/missing becomes too much for it to make any usable power. I Run the tooth logger and I'm not seeing any of the issues with the CPS as is described in the mega manual or diys manual for possible weak crank reference signal. I opened the box and turned the screw several full turns and I don't see any tooth logger or combination logger changes at all. Does anyone know how many turns that little screw actually has? I can put my OG dme in there with the JC tune and it will rip to the Rev limiter without any issue at all and run golden and fast as fuhh. I found a timing table online to work with that actually feels spot on, with it on the ms2 it feels almost twice as quick to 5k as the dme with turners chip. Although any manipulation of it above 5k makes no positive or negative change in the missing over 5k issue. I'm also currently running the tuner studio ultra. I'm not sure if that's the fanciest one you can get. I'll buy what ever though. We will see what happens Friday morning. I'll post the dyno pulls and if we discover the issue I'll be sure to post that as well
                    • Digitalwave
                      is a poseur
                      • 6282
                      #115
                      It sounds like all of your issues is because you have not tuned the car at all. You can't download some base map and expect your car to run properly on it.
                      RISING EDGE
                      • Joegreen02
                        • Dec 2018
                        • 80
                        #116
                        Yeah I was thinking maybe squirt wasn't getting a good signal from the crank sensor. We will see friday
                        • Digitalwave
                          is a poseur
                          • 6282
                          #117
                          If you don't have any sync loss, it's not the CPS. It's probably breaking up because it's untuned.
                          RISING EDGE
                          • Joegreen02
                            • Dec 2018
                            • 80
                            #118
                            I gotcha. Yeah honestly like I said, I'm not terribly familiar with tuning. I thought since I paid a grand for the mspnp2 system it would come out of the box with a tune similar to what Turner Motorsport did with the chip, and the car would run even better and be custom tunable out of the box. My miss perception of the product is all.
                            • turbski
                              • Jul 2018
                              • 329
                              #119
                              if I wanted to see how my injectors are running using megalog viewer would the correct plot to be looking at be pulse width and duty cycle1?
                              • Joegreen02
                                • Dec 2018
                                • 80
                                #120
                                On the dyno this morning. Everything went pretty good. This guy at sanoli performance Edward is the real thing. Definitely knows his MS and making power. I brought it in on the tune I had running and put down. 123 hp on the initial pull. He did a little tweeting and boom 148 hp 157 trq he kept fooling around with it till he wound up at 153hp 167 trq. Pretty respectable for a mostly stock car I think. [emoji2369]
                                Problem. The missing above 5k is still there. He thought it was fuel cut and recommended doing the injectors and a 255 pump. I have the walbro 255 in the tank now but still have the missing issue over 5k
                                Question. How do I properly check the action and sync of this crank sensor? I have a brand spanking new bmw cps in the car now about to start pissing with the injectors.
                                Just FYI my goal for the car is 250 hp and close to 300 trq at the wheels via FI once I have these little issues settled and decide what size turbo I really need for my style of shenanigans
                                Second question how much turn out of that screw in the blue box can I expect to make a difference in cps sensitivity. When I was messing with it before I couldn't get it to lose or gain anything on the tooth logger[emoji2369]
