a/c idle up circuit
  • 2002tiiguy
    • Jul 2013
    • 467
    a/c idle up circuit
    Run jumper from pin 40 on ecu connector to input of 5V regulator on proto section of whodwhos ms, run output of regulator to pin 18 on microsquirt header. Anyone have any input whether this is good or bad thinking?
  • varg
    Florida Turbo Man
    • May 2014
    • 3413
    Something like a 7805 in a TO92 package with pin 40 feeding the input instead of a generic 2A2222A based going high input circuit? Should work just fine. However, you must make sure that the 5v regulator is under enough load to be in regulation, the minimum current depends on the part.
    IG @turbovarg
    '91 318is, M20 turbo
    • 2002tiiguy
      • Jul 2013
      • 467
      Lol yup thats what i was thinking, i didnt understand why people were going through making their own circuit when a 5v regulator is readily available, reliable and only takes up 3 pins on the proto
      Sent from my SM-N920V using Tapatalk
      • 2002tiiguy
        • Jul 2013
        • 467
        Soldered it together, it works
        • varg
          Florida Turbo Man
          • May 2014
          • 3413
          Good to know. I was concerned that maybe the logic-level input to the MS would not draw enough current to keep in regulation but I guess that was unfounded.
          IG @turbovarg
