injector offset spec
  • zaq123
    • Jul 2016
    • 1559
    Bosch 0280150947 blue, 24lbs.
    Anyone has data for the voltage offset aka dead time aka latency for this things? Want to make sure I got the correct value in MS2
  • zaq123
    • Jul 2016
    • 1559
    no one used 24lbs blue tops with Megasquirt?
    • Jaxx_
      • Dec 2009
      • 1880
      Injector offset is less critical than some make it out to be. With your size injectors I would just put in a value like .9 or 1.0 if they are high-z. Unless you are having issues getting smooth idle and predictable AFRs, it's probably not worth characterizing them yourself or paying someone to do it.
      • Digitalwave
        is a poseur
        • 6299
        Check the MSExtra forums, there are some rudimentary tests you can do to find the settings by changing the number of squirts. I found mine to be much faster than the recommend 1.0ms or whatever it is (mine are about 0.69ms). Mine are Bosch 24lb but a different part number than yours.
        RISING EDGE
        • digger
          • Nov 2005
          • 6173
          then select from drop down
