V-Band question
  • E30Gus
    • Jun 2008
    • 781
    V-Band question
    Is there any reason I shouldn't mix steel and SS V-Band clamps so that I can mate the SS and Steel pipes together?
    • 34844
    regular steel rusts, but otherwise no. it won't cause a galvanic corrosion issue or anything.
    • Bglad
      • Jul 2010
      • 562
      Galvanic corrosion only occurs when there is electrical current passing though.
      But as Nando states there will be no issue aside from the normal material property differences from Steel vs SS.
      • E30Gus
        • Jun 2008
        • 781
        Thanks guys!
        Good to know I don't have to put zinc's on my drive shaft lol
        • vpilarrt
          • Jun 2006
          • 2096
          You're partially correct. When 2 dissimilar metals (like stainless steel and steel)are in electrical contact and in the presence of an electrolyte (water, for instance) an electrical current will be generated in the form of free flow of ions from 1 metal to the other. This will cause 1 of the metals (the more anodic) to corrode more quickly than normal and the other metal corrode more slowly than normal.
          In the case of your exhaust pipe joint the tightness of the joint should keep out almost all of the liquid water so the chances of galvanic corrosion are minimal.
          • Northern
            I like cupcakes & sh!tboxes
            • 5256
            I agree until the second paragraph.
            When it rains, there's going to be an awful lot of water getting sprayed around under the car. The multiple notches in the vband clamp is going to let lots of water sit next to the joint between the two, and capillary action will do the rest.
            That said, this is the best way to mate the two materials. Stainless and non stainless steels aren't going to react crazily with each other.
            Originally posted by priapism
            Originally posted by shameson
