E30 Exhaust Disappointment
  • 6th Element
    • Apr 2015
    • 20
    I have an ‘89 325i with the stock M20 and a Turner Chip.
    my exhaust system has been stock with the exception of a Borla Muffler for quite some time now. I had been contemplating changing the exhaust note a bit. I was hoping to acquire a more raspy sound. So today I had an exhaust shop replace the cats with straight pipes and to my disappointment, it sounds god awful. Sort of like a 325 E46 with a muffler delete
    it has a very “empty/hollow” sound. I’m not sure if it’s because I have stock manifolds or not.
    My question for you guys is, what makes the M20 sound raspy? Would an X pipe change the tone as opposed to just straight pipes? Maybe even some eBay long tube headers?
    I’m aware that exhaust modifications won’t gain any power on a stock M20, maybe even lose some low end power, but in all honestly, this car’s my weekend toy and occasional canyon carver.
    thank you guys in advance!
  • Stanley Rockafella
    • Aug 2011
    • 4062
    https://www.holley.com/brands/flowma...ies_big_block/
    This'll get it flowing freely and give you that stock sound (not empty/hollow) yet quiet.
    Also a dual in, dual out, so it'll weld up exactly where the old cat/resonator was - similar dimensions too.
    • onesecond
      • Apr 2018
      • 159
      Go on on a few websites, see what they offer and then look them up on youtube. There are tons of videos with their exhaust notes recorded
      • varg
        Florida Turbo Man
        • May 2014
        • 3411
        Rasp and "hollow" typically go hand in hand, just listen to a new edge mustang with flowmasters. Hokey explanations about pulse order and such you'll find on forums aside, if you look at an actual spectrogram of different exhaust sounds, rasp is identifiable as excess of higher frequency noise relative to the lower fundamental frequency noise that is the frequency of exhaust pulses. Funny that you're looking for the rasp, most people try to eliminate it. Since the M20 doesn't rev high enough to be a screamer where the more pleasant high frequency noises dominate the rasp, mid range rasp typically is not viewed as pleasant. Straight through mufflers and narrower pipes (i.e. stock size pipe and mufflers) will tend to let the rasp through without the "hollow" mid/low frequency resonance that you typically get from big and/or thin pipes. Cats are great for eliminating resonance since they're basically a resonator with a flow control device (the matrix) inside them. So choose a bolt on system based on clips, or weld a resonator in.
        IG @turbovarg
        '91 318is, M20 turbo
        • roguetoaster
          Biggus Tippus
          • 7830
          OP, just stick a potato in your exhaust.
          • e30strokr
            • 211
            get the ebay exhaust manifolds thinner metal amplifies the rasp sound..
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5585
              single in dual out is the key for nice m20 note
              y pipe after a high flow cat, then a nice long resonator into a single in dual out vibrant and you'll come back and thank me
              Best sound ever.. I've tried it all and this is the one
              • Reichart12
                • Aug 2012
                • 2165
                Not sure I have ever heard anybody want rasp... but here's my set up. Sounds great. Bavauto long tube headers into a single 2.5" into a vibrant resonator and vibrant muffler.
                Instagram: Reichart12
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  PO-TA-TO. Do it.
                  • 6th Element
                    • Apr 2015
                    • 20
                    Thank you for the long informative response. Much appreciated!
                    I AM in fact hungry. Baked potatoes sound pretty darn good this time of year
                    I’ll try to find some YouTube clips of a similar setup. Thank you!
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5585
                      I'll take a vid of mine after work for you
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Waiting for the vid of your baked potato.
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5585
                          Brace yourself for an offensively mediocre e30
                          • e30strokr
                            • 211
                            a resonator will remove the rasp and it will deepen the tone..I got a vibrant muffler and added a resonator to lower the rasp/tone... it sounds deeper then when I had the Xpro muffler
                            heres an example
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5585
                              mine sounds totally different than that. Mine is no where near that deep.
                              Also, that vid is an m50 with vibrant rez and a whatever muff.
                              I have a bottleneck rez with a vibrant muff hehehe
                              Also, their (vibrant) style of resonators are essentially small mufflers that are much wider in relation to how long they are.
                              In my experience a long rez with a slightly larger diameter than the pipe will yield a lighter tone with no drone.
