Dope I wanna se video of this beast
Turbo M20 Build
Thanks guys...it's been a long time since I updated this thread. I'm waiting on the block to get back from the machine shop...should have it next weekend. Should have her running in about a month
Build Thread
http://www.e30tech.com/forum/showthread.php?t=84988
"When In Doubt Boost It Out"
~89 325I Turbo 11.90 @ 121~
~ 420whp/420tq~
15psi
~Paul Burke Built 2.8L Stroked M20
~666 Divided Mani T3
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Super sweet build. Looks like your doing it right!
I'm also in for videos.
-'87 325 - ratbox swap http://www.r3vlimited.com/board/show...77#post3250277 << Check out my Wanted thread
Originally posted by beefjurky69 View PostThanks guys...it's been a long time since I updated this thread. I'm waiting on the block to get back from the machine shop...should have it next weekend. Should have her running in about a monthYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
[QUOTE=einstein57;3034672]Wait what? Does that mean you did finish the car at some point and blew the engine our your putting in a rebuilt engine in to a car that has never been properly setup
I didn't finish the car but I did get it running...what happen was while driving the car around the block to make sure everything was in working shape a rock or something hit the reluctor ring that goes around the crank pulley for the crank sensor.
The car was running crappy after the drive as if the timing belt jump...had no idea the ring was pressed on the crank pulley as it was powder coated...so after months of try to figure it out with tons of cranking and no starting I noticed the ring had moved.
I pulled the crank wheel off and fixed the issue the car started right up and idled perfect...but since I was so excited about the car running again I never drained the oil which had tons of fuel in it from too many crank no stats that it developed a rod knock.
So I got the motor rebuilt to oem spec with all new hardware/rings/bearing and all new gaskets...should be up and running soon.Last edited by beefjurky69; 03-08-2012, 04:16 AM.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Damn. I thought my luck was bad.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Wow love this, sub'd for meh future turbo setupE-9 Motorsports
Supported by:
Insane Innovations LLC
DTMFiberwerkz
Achilles Radial
Thanks guys...head was already done, I'm machining the block because I spun a bearing and had a rod knock. So I got the bottom end rebuilt...new rings new bearing know good crank off a spare motor I had.
Getting the block back tomorrow so I'll have some pics up this weekend.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
^ thanks man...here's are a few pics of the fresh block and new colore scheme for Mani and valve cover
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
That looks exactly like my block right now. Waiting on the machine shop to finish my rods and head. Then we'll be in business! I can't wait to see where you take this thing.
I'm mentally piecing together a turbo for my M20 that I'm putting together now and when I finish my second M20 that will have a lot of work done to it, we will be talking about quite bit more boost. Right now I just want like 240whp. That's not too much to ask, is it? :D
