Turbo M20 Build
  • bobross
    • Jul 2005
    • 753
    #136
    Originally posted by beefjurky69
    Thanks Greg...I'm going to route them a diggerant way and see how that works. If I got to buy the dei wraps I will.
    How's the car feeling at 400hp is it a beast? I'm hoping to get up and running for break in on sat if everything goes as planned.
    Hah. feels good man.
    Went out to ICS dyno day and sat back and watched as the 12v made the most power of the day ;)
    -Greg
    90 325isT - 12.2 @ 120ish - Dyno Results
    b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
    • beefjurky69
      • 613
      #137
      Usually what happens when ppl sleep on 12v engines...glad to hear your car is doing well though congrats. Hopefully I can post a vid this weekend of my car running.
      Build Thread
      http://www.e30tech.com/forum/showthread.php?t=84988
      "When In Doubt Boost It Out"
      ~89 325I Turbo 11.90 @ 121~
      ~ 420whp/420tq~
      15psi
      ~Paul Burke Built 2.8L Stroked M20
      ~666 Divided Mani T3
      ~6262 T3 Turbo
      ~O'ringed Block SS
      ~Custom Fuel System
      ~3'' Turbo Back
      ~50mm Tial Bov
      ~Dual Tial 38 Gates
      • beefjurky69
        • 613
        #138
        So the car is up and running . Feels good to hear those rockers once again lol. Everything so far went smooth. Did a heat cycle then let cool down and re torqued the head.
        Took it for a quick drive to see how everything felt and it felt great.
        Seems to be loading up a little bit and low rpm's but I still need to get it tuned.
        The tune session is this sat tuning at wastegate spring pressure which is 11 psi. Drive it around for about a month or so just to make sure everything is perfect and I have no leaks of any kind before going for more power.
        I'm hoping for something around 300 horse at 11 psi but we'll see what happens. Here's a crappy vid my buddy took but it's better than nothing I'll post a few more up this week as I break in the motor.
        __________________
        Build Thread
        ~ 420whp/420tq~
        15psi
        ~6262 T3 Turbo
        ~O'ringed Block SS
        ~Custom Fuel System
        ~3'' Turbo Back
        ~50mm Tial Bov
        ~Dual Tial 38 Gates
        • Cronopoulos
          • Jul 2011
          • 2187
          #139
          BADASS Build!!! What exhaust(s) is that, sounds amazing!
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • beefjurky69
            • 613
            #140
            Its a custom 3'' one i fabbed up with a magnaflow at the end :)
            Build Thread
            ~ 420whp/420tq~
            15psi
            ~6262 T3 Turbo
            ~O'ringed Block SS
            ~Custom Fuel System
            ~3'' Turbo Back
            ~50mm Tial Bov
            ~Dual Tial 38 Gates
            • Cronopoulos
              • Jul 2011
              • 2187
              #141
              Thanks! Do you sell any manifolds that you make?
              • beefjurky69
                • 613
                #142
                I haven't made a manifold yet so I don't really sell them. I kinda feel it cheaper just to buy one since I don't have all the proper tools and jigs to make one.
                Build Thread
                ~ 420whp/420tq~
                15psi
                ~6262 T3 Turbo
                ~O'ringed Block SS
                ~Custom Fuel System
                ~3'' Turbo Back
                ~50mm Tial Bov
                ~Dual Tial 38 Gates
                • beefjurky69
                  • 613
                  #143
                  Been a while since I updated this thread. The car ran well for a while and after a month I notices the headgasket had a slight leak fom cyl 1. So I ripped it apart before anything got worse and sure enough the headgasket had a tear in it right were the water jacket is.
                  That led me to weld the jackets and oring the block. Should have the head back this week. Had the head decked and did a 3 angle valve job as the seats were warped from welding the jackets. Here are a few pics of the head welded and the block oringed.
                  Build Thread
                  ~ 420whp/420tq~
                  15psi
                  ~6262 T3 Turbo
                  ~O'ringed Block SS
                  ~Custom Fuel System
                  ~3'' Turbo Back
                  ~50mm Tial Bov
                  ~Dual Tial 38 Gates
                  • sayed ali
                    • 762
                    #144
                    Nice job on the O-Ring
                    M20B28 Turbo
                    My Build Thread
                    http://www.r3vlimited.com/board/showthread.php?t=255839
                    • beefjurky69
                      • 613
                      #145
                      Thanks dude...pretty easy to do with the groove-o-matic
                      Build Thread
                      ~ 420whp/420tq~
                      15psi
                      ~6262 T3 Turbo
                      ~O'ringed Block SS
                      ~Custom Fuel System
                      ~3'' Turbo Back
                      ~50mm Tial Bov
                      ~Dual Tial 38 Gates
                      • durtyE30
                        • 707
                        #146
                        This build is intense.
                        • beefjurky69
                          • 613
                          #147
                          It was done already...but then again it's a project car and this is what it takes.
                          Build Thread
                          ~ 420whp/420tq~
                          15psi
                          ~6262 T3 Turbo
                          ~O'ringed Block SS
                          ~Custom Fuel System
                          ~3'' Turbo Back
                          ~50mm Tial Bov
                          ~Dual Tial 38 Gates
                          • Simple_Smith
                            • Aug 2011
                            • 585
                            #148
                            damn dude sick build so far. i'm diggin the mac box/snap-on tools combo. i have the same box haha. definitely taking notes for my turbo build. how much should i expect to spend at a machine shop to get my block and head o-ringed and the water jackets welded?
                            1989 JDM-Tech 2
                            2010 335 D for daily
                            • beefjurky69
                              • 613
                              #149
                              Thanks man...not sure how much it would cost cause I did everything myself. I rented the groove-o-matic from max psi.
                              Build Thread
                              ~ 420whp/420tq~
                              15psi
                              ~6262 T3 Turbo
                              ~O'ringed Block SS
                              ~Custom Fuel System
                              ~3'' Turbo Back
                              ~50mm Tial Bov
                              ~Dual Tial 38 Gates
                              • trackstar
                                • 7
                                #150
                                Awesome stuff. Cant wait to see the numbers
