30lb injector Help ????
  • 1990e30coupe
    • Jul 2010
    • 126
    I was woundering if anyone on here knows where to find 30lb injectors for my m20b25 turbo project? If anyone can point me in the right direction or give me a link that has some with reasonable prices i would appretiate all the help, Thanks.
    What BMW means to me: Breaks My Wallet
  • einstein57
    • Jun 2007
    • 10780
    ebay for some ford racing. used ones go for about 100 rebuilt. Summit racing injectors aren't bad. I think they are the same ones that TCD uses. And there is always diyautotune. I'd part with my almost new 30lb injectors for 180
    www.gecoils.com
    • Dj Buttchug
      • Jun 2010
      • 7677
      30lb volvo injectors. ebay it
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • einstein57
        • Jun 2007
        • 10780
        Volvo injectors are low impedance and won't work with a 173 ecu if your going that route. I also have a set of volvo injectors for 40.
        www.gecoils.com
        • 1990e30coupe
          • Jul 2010
          • 126
          well i am going to be running stand alone from diyauto. Will 30lbers run 12 pounds of boost with stand alone ok or should i look for 34lbers?
            • 34839
            they might work but they are a bit small. I'd start at 42# so you'll have some headroom left.
            low impedance injectors are more work than they are worth these days, even if you have standalone.
            • ForcedFirebird
              • Feb 2007
              • 8300
              Injectors from a 3800 GM supercharged v6 are a direct fit, 36lb/hr, and plentiful.
              john@m20guru.com
              Links:
