is anyone running E85 on their boosted cars?
  • jahen
    • 71
    8.3bar?
      • 34844
      req fuel is a fuel constant (pulsewidth adder) used in MS and similarily by other standalone systems. Essentially it's the base pulsewidth for a given injector size matched to the displacement of your engine. by increasing it you can make it run richer without touching the fuel map.
      • ogbimmer
        • Jul 2010
        • 936
        Originally posted by Good & Tight
        Been running E85 for 2 years now on the M30 and love the stuff.
        The advantages for boosted engines are:
        More power w/less boost
        Run more timing
        Engine runs cooler
        Oil stays cleaner
        Exhaust does not stink
        As far as fuel lines, I still am using the original tank to pump hose, the rest I replaced since I am running two bosch 044's.
        One pump is good for around 430rwhp.
        Main thing is larger injectors and enough fuel pump.
        dude your the man, and a true innovator in the e30 game!!
        question though should I run e85 on my m50
        or pump 93 and meth injection
        I know with the meth I could fill up at any pump and run the meth at higher boost a similar effect to e85.
        also I have 1000cc injectors and I am worried about maxing them out if I run e85
        " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
        • Good & Tight
          • Apr 2004
          • 2057
          With 1000cc injectors you should be good for over 600whp with E85.
          If it's a daily go with the 93 and meth setup.
          If you don't care about gas mileage than go with the E85.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • ogbimmer
            • Jul 2010
            • 936
            think they would make similar numbers? I know with meth it should burn like 110ish octane right vs e85 104. Does that sound about right?
            • ogbimmer
              • Jul 2010
              • 936
              One last question otis?? what do you do in the winter when it is e70 instead of e85? Do you have to re-tune your car, or do you have 2 tunes one for winter and one for summer. Last has your car ever not started or had any problems running on e85?
              • Good & Tight
                • Apr 2004
                • 2057
                Living in South Florida it's summer year round, haven't really noticed a difference in AFR's.
                When it dips into the 40's it is hard to start, but that has to do with the warm up enrichment settings that need to be adjusted.
                • ogbimmer
                  • Jul 2010
                  • 936
                  so basically If its below 40 I would have a hard time driving the car. I guess thats not to bad of a trade. I have been looking up e85 station locations all for the past hour lol
                  • learningcurve86
                    • May 2008
                    • 715
                    Originally posted by der affe
                    It made it to the final 4 until it sheared the crank pulley/timing gear off on the line for the semi finals.
                    Did anyone else notice this? That's just incredible in my mind. Any chance there's a photo of this?
                    Greg
