Where did you get your injectors?
  • sacse30
    • Jan 2010
    • 123
    Looking to get some 30lb injectors. Any suggestions on where and what kind to buy?
  • sacse30
    • Jan 2010
    • 123
    Will these fit my m20?
    • einstein57
      • Jun 2007
      • 10780
      yes.
      www.gecoils.com
      • sacse30
        • Jan 2010
        • 123
        When buying off ebay, what am I looking for to know that they will fit my motor? I see tons of 30lb injectors on there, but I'm not sure about fitment and such.
          • 34839
          basically all bosch style high impedance injectors will fit
          • ieatpeople
            • Mar 2008
            • 883
            there is a website called fuelinjectorconnection.com
            they seem to know what they're doing.....
            Originally posted by BillBrasky
            That's like Vlad challenging Chip Foose to a car painting contest.
            Originally posted by acolella76
            i'm pretty sure 'Phillis' is short for syphilis
            2007 CVPI, stock and slow
            1994 tercel, 5efhe swap, i/h/e
            1984 t-type, 5.3/th350 swap in progress
            My newest addition:
            Rebecca Arlene, born 4/19/2013
            • einstein57
              • Jun 2007
              • 10780
              basically google the part # and look for the impedance. If its around 14 your good (assuming the shape is the same as stock)
              www.gecoils.com
              • Midnighttuning
                • Feb 2011
                • 30
                I have seen it many times on ebay where injectors are advertised at 30Lb, 42LB, ext ext and in fact they are not
                Use this as a guide to cross reference the part # as well as many other specs
                BarrieM/// BMW Tuner
                Email:midnight-tuning@rogers.com
                • twitch
                  • 60
                  I have those same injectors from ebay on my car and they do just fine.What boost are you planning on running though.I kinda wish I had got 42#
                  • bmw325csi
                    • May 2007
                    • 4045
                    Just be careful with those tips! I used those that came in a rebuild kit and one of the blue tips came loose in the chamber and wouldn't let the gas from the injector reach the combustion chamber. I had to remove the intake manifold to get it out.
                    In other words, make sure they are on there good.
                    harry/harout
                    • Dublbass_monster
                      • Nov 2011
                      • 23
                      im confused
                      so ive got the stock '89i head, victor reinz factory HG, and metric blues torqued to 80ft. lbs., 24# mustang injectors (just to get started), and im currently running Aeromotive Stealth 340lph fuel pump, factory fpr 3.0 bar, ive got an AEM eugo digital widevand boost controller set for 10% duty cycle of 10psi(just to get started), plugs gapped to .032, i havent put an adjustable fpr on return line post-stock fpr yet, should I? Also when adjusting the AFM do I need to put the idle screw all the way in before I start adjusting the tension on the wheel/flap? I've researched this but still don't quit understand. Running ebay 6:2:1 turbo S.S. turbo manifold with a junky hand me down turbo from a buddys old turbo kit he bought and never used the turbo, its like somw japanese t3/t4 hybrid with an a/r of .50. So basically I just need to tweak my AFM spring tension and adjust the FMU to match a 14.7-15.2 sweeping idle and a solid 12.5 at WOT? Is it really this easy and I'm just making it difficult for myself buy replacing parts that don't matter?
                      *Ready to drive.*
                      • custom e30
                        • Nov 2009
                        • 347
                        i went to a junk yard and found red 30lb injectors in turbo charged Volvo's,
                        • einstein57
                          • Jun 2007
                          • 10780
                          *Ready to drive.*
                          A couple errors on your build.
                          1) Victor Reinz headgaskets are garbage. Expect to replace it very soon.
                          2) 80lbs is way to much. Thats why people snap them and complain they are crap. You don't see people torquing ARPs to 80lbs do you? I torque my blues to 65lbs. I'd buy another set of bolts when you replace that garbage headgasket with a Goezte or Elring.
                          3) .032 might be too much of a gap on a boosted car without an MSD unit. Go with .028 to start.
                          4) I did not see anything about a timing retard chip on your parts list. There is a pretty good write up on e30tech on how to tune a AFM for boost.
                          5) You need a rising rate FPR for boosted cars. You can usually find a Begi unit used for pretty cheap.
                          www.gecoils.com
                          • MaksV
                            • 1042
                            depending on the size you need, check out my thread in my sig!
                            CHEAP REBUILT INJECTORS
                            Need Quality Brakes? BimmerBrakes has it!
                            For anything Else go with BluntTech!
                            • BMWZ318is
                              • Nov 2008
                              • 102
                              just don't buy venom injector that's what im using and they are terrible.
