So you had problems with leaning out with the 30lb injectors, if I'm gonna be running 10-12psi like you are then I should go for 42lb injectors like you just did? did you change your fuel pump for a larger one or is it still stock?
Miller WAR chip e/i "stroker" w/HX35 issues
Originally posted by The Humjet View PostSo you had problems with leaning out with the 30lb injectors, if I'm gonna be running 10-12psi like you are then I should go for 42lb injectors like you just did? did you change your fuel pump for a larger one or is it still stock?
30# injectors would be fine for 10-12psi, but that's about it. Their duty cycle is about maxed out at that point. You could probably do 15psi, as was my plan for them, but that's maxing them out and never a good thing.
I haven't fired up the car and tried adjusting the idle fueling yet with the 42# injectors. I'm using the Miller WAR chip on the stock Motronic DME, and Motronic has trouble managing injectors larger than 30#.
Get a wideband and keep an eye on it, you'll be fine.
Here is my project thread on my local forum:
Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
Maybe Brody will be checking the thread and will chime in. I haven't asked Miller, so who knows. I'm just going by what I've read about flash tunes on Motronic. I'm sure Miller sees the same limitations with the WAR chip.sigpic
Motronic does not have trouble with larger than 30# injectors - you just have to know how to calibrate it properly. 42's are no problem, 55's would even be fine. We haven't had the need to set up an M20 for higher than 30's.
30# injectors will be fine for around 350 WHP, 36# injectors will be fine for 420-430 HP 42's will support 500 - 550
Nice to hear from you Brody, I just purchased a second hand w.a.r and maf from MonkeyMadness (Jeremy Duncan) someone you might know. When I get deaper into my turbo build I hope to keep in touch with you via email. Im gonna be learning the software as time goes on. But I think it would be better to do a remote tuning at my local dyno shop so I can get a perfect tune by someone who knows more about this software. Does that sound ok?
Originally posted by The Humjet View Postany updates on your car I just purchased a Miller W.A.R and Maf waiting for it in the mail. How's the 42lbs injectors treating you/
Haven't driven too much, but I did go out and have a little fun. haven't done any hard pulls yet.
I am running fairly rich, with my highest AFR MAYBE reading 13:1, I'd say I'm averaging around 11.5-12.
I spoke with Brody about a base tune for the 42#, so I'm hoping to try that out soon.sigpic
Did you have to buy the 173 turbo .ecu "plugin" to tune your turbo setup, or are you using how it came right out of the box?
also..when you're running your maf is it infront of the turbo behind the air-filter, or is it en-route to the throttle body?Last edited by Sputnik; 06-25-2011, 05:33 PM.
Originally posted by brody View PostMotronic does not have trouble with larger than 30# injectors - you just have to know how to calibrate it properly. 42's are no problem, 55's would even be fine. We haven't had the need to set up an M20 for higher than 30's.
Would you be able to get back to me please I need a turbo tune for 30# injectors for my M20 build (war chip/ maf GenIII / smart fan).
Few e-mails sent to you and no response back :(
e-mail me please: dmedeiros1974@gmail.com
Sorry did not want to highjack thread. Thanks BrodyDenny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/
Originally posted by bukaki_bob View PostDid you have to buy the 173 turbo .ecu "plugin" to tune your turbo setup, or are you using how it came right out of the box?
My MAF is in front of the turbo. They are pull through MAF's so they need to ge before the turbo. I have a 3.5" 90 degree coupler with my MAF and a cone filter behind the headlight. Barely fits. In the future, I may route the intake through the hole left from the a/c dryer and have a filter behind the front bumper.
Right now it's pulling nicely running 15psi. I'd bet the T3 would spool a lot faster than my T3/T4, but 15psi would be about the max I could run. This turbo should be good for around 20psi max.sigpic
Also whats size maf are you running?
