m50 hx40 newbie need some opions
http://www.youtube.com/watch?v=qxdbI...eature=related
check out this vid, i want my turbo set up to be like this lolNeed a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
mtech 2 325ic
http://www.r3vlimited.com/board/pict...pictureid=7968
check out my donut vid
http://www.youtube.com/watch?v=Tw0paUP1FEQComment
im sure it will be the same exact thing for the s50 then. i just dont want to drop in the motor and have to pull it back out to replace the studs and gasket. seems like a lot of work. so now im debating if i should wait on the turbo n just run the s50 or just do the swap and the turbo later....
mtech 2 325ic
Changing the HG isn't that hard it'll only take you a morning to do. You don't need to take the motor out just to change head studs and replace with mls.
It's when you sit down and add up costs that turbocharging isn't cheap, all the small things add up. You think a wastegate ahh only $200 but add that with pipe work, turbo, tune and clutch and even the necessities that you need but don't realise such as gauges that the costs do add up. For my m20 it added up to $4000-$5000. That total cost will be cheaper in the US so don't get too scared but thats how it stood for me here in Australia. But when it's done it's gonna be the most awsome thing to own and any other car would be put to shame :up:Comment
man i cant wait until its done. so for now im just going to drop in the s50 with a clutch and flywheel, then later on as i save up my money i will guy everything i need at once! i want to do things right and so i can make more power without things messing up on me.i know it will be well worth it in the end. i will keep the both of you updated on my progress incase i run into problems and need your help. thank you much
mtech 2 325ic
No worries I'm on the same boat, I'm dropping in an m20 2.7 that I also want to turbo all I need now is $$$ to buy the the damn partsComment
man i cant wait until its done. so for now im just going to drop in the s50 with a clutch and flywheel, then later on as i save up my money i will guy everything i need at once! i want to do things right and so i can make more power without things messing up on me.i know it will be well worth it in the end. i will keep the both of you updated on my progress incase i run into problems and need your help. thank you muchno more boosted m20, 91 318i...Comment
mtech 2 325ic
