you haven't seen mine my only issue is the bolts on the tband clamps are supper long and push my grills out slightly but that's just trimming the bolt which i don't feel like doing
Best way to fit intercooler
Lol, how much sanding do you have left? was it only the vertical surfaces that have the orange peel? spray that last coat on?Comment
theres enough info in here for him to figure it out. need to take a picture and be like why orange peel
because racecarComment
lol i still havent finished mine, the vertical pieces needs so much more but when you go fast enough by some one they can see it
or in your case add enough smoke no one will tellComment
I have an early model, and don't have the big ES or IS front air dam. Is there a spot where I could put a front mount and not have it showing (much), or is it possible to run 2 little side mounts behind the headlights? I don't have a washer bottle anymore, or the plastic shields that go behind the headlights. I have been searching like mad but haven't been coming up with much. Maybe I'm not searching with the correct terms, but all I can find are pictures of early models with the big valanceComment
