Need new turbo... Recommendations please.
  • jaywood
    • Jul 2010
    • 4528
    That's brand new ^^^ if you want to buy a used one it's a bunch cheaper. These Holsets are real nice turbos and last a long time.
    I got a rebuilt H1C with oil lines for $150.
    • FLG
      • Sep 2011
      • 3165
      I have this one already... Didn't mind spending the extra cash. It's quite nice and a lot bigger
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • jaywood
        • Jul 2010
        • 4528
        Is that the one from ebay? Looks nice!!
        • FLG
          • Sep 2011
          • 3165
          Yep came here in a day!
          Brand new, heavy fricken thing! Just need to modify my actuator rod as this one is longer and see how I'm gonna do the piping. Also might need to weld a new vband flange on as it's just a hair smaller... Will try to make it work first
          • FLG
            • Sep 2011
            • 3165
            OK so its all in...
            I think something is a bit wrong though, i know its a big turbo but im getting quite a bit of lag. I mean when it gets to boost, its great....but getting there takes forever. Granted i have 3.73's so my gearing is short...but i build very little boost in first, 2'nd is better. There rest of the gears again are better but dosnt seem to be able to start building boost till about 4k, with my old turbo i could be in 5th and go to pass someone and boost just about as soon as i touch the throttle, not the case anymore. Any ideas to what it could be? Or am i gonna have to sell this guy and get something smaller?
            Sadly, seems it was quicker with the ebay garbage due to the lag. Is my current tune killing spool?
            Eh, i need some help...first turbo car.
            From my reading it seems i should be spooling much quicker....
            • jaywood
              • Jul 2010
              • 4528
              What manifold are you running? Is it split pulse?
              • FLG
                • Sep 2011
                • 3165
                Im running an ebay crap manifold......im gonna have to drop some money on a twin scroll arent i? or is there a split pulse manifold i can pick up and not break the bank.
                This is currently whats there
                • jaywood
                  • Jul 2010
                  • 4528
                  The H1C that I have is a split pulse and the OBX adapter is not...I'll be modifying the adapter and making it a split pulse adapter.
                  • FLG
                    • Sep 2011
                    • 3165
                    Im going to make something to check for boost leaks, but im thinking i should be spooling sooner either way.
                    • jaywood
                      • Jul 2010
                      • 4528
                      Pretty nice setup...
                      http://forums.nasioc.com/forums/show....php?t=2205161
                      No need for something that fancy ^^ http://www.6speedonline.com/forums/9...ig-w-pics.html
                      • FLG
                        • Sep 2011
                        • 3165
                        Thats what i was going to make.
                        Hoping i find a nice big boost leak, if not i might have to sell this guy and go smaller....though i really dont feel like it. Was NOT fun mounting this beast up.
                        I mean when boost hits, she jumps from a few lb's to 18 psi quick! But just getting the thing to start to spool is killing me.
                        • jaywood
                          • Jul 2010
                          • 4528
                          I don't have any first hand experience with the difference, but I have read from many places that the split pulse manifold does make a BIG difference in spool up time...
                          • Cronopoulos
                            • Jul 2011
                            • 2187
                            You are correct!
                            FLG - How many pounds are you running?
                            Project log -- DIRTY 30
                            2.7i * Megasquirt tuned * E85 powered
                            • FLG
                              • Sep 2011
                              • 3165
                              I havent been able to dial it in just yet with my ebc, going to switch to my smaller wastegate actuator as the holset one seems to be pretty stiff, turned up it will boost 20psi. Ive got it somewhat settled at around 15-18 but i didnt drive around enough to get it perfect.
                              Generally id like to set the low setting on my ebc to around 10psi or so, the high to around 16-18 psi
                              Where can i find a split pulse manifold?
                              • FLG
                                • Sep 2011
                                • 3165
                                Also i could not find a correct restrictor so temp im running my -4an line to my turbo, oil pressure is about 50-60 psi when you get on it, from my reading too much oil pressure can increase spool time? But that badly?
